Issue 74 Canopy Options
jonny7england
#1 Posted : 17 May 2012 14:36:16
Hi there shipmates...In issue 74 we fit the canopy, but I am at a bit of a quandary here? I have test fitted the canopy roof and like picture 1 page 11 I have found that the canopy support is well out!! The support touches the roof at the rear but there is a 2mm gap at the front? I am a bit dubious about filing the supports down...If I do have to file the tops of the supports, is it from the rear of them? Much obliged for you imput shipmates.
Blink Confused
thomasmoult
#2 Posted : 17 May 2012 14:40:58
Hi mate,
Mine was the same as this, I filed a lot from the rear of the supports but there was still a slight gap when I fitted them. I found that when its all attached and painted, the dark paint tends to lessen the visibility of the gap anyway, and I also applied a thicker coat around the gap so it filled it a bit more as well.
Hope that helps!
Tom
thomasmoult
#3 Posted : 17 May 2012 14:42:08
I also drilled holes in the backs of the supports and added a brass pin to make it stronger when in the hull, might be worth considering!
Tom
daffy09
#4 Posted : 17 May 2012 19:26:05
Hi Jonny7england,
Your photo shows me you have a similar problem to me.
Don't know if it's the right solution for you, as I was doubtful about filing down the sides myself,so I altered the angle of the back of the canopy top to drop the front end, which brought it line with the sides. Mine turned out alright, but using this method you may find (if you try this), you might need to adjust the back of the side panels also because making the angle more acute makes it marginally narrower front to back.
Happy building
David
StefanDV
#5 Posted : 18 May 2012 11:46:02
I'm not there yet Jonny, but from my understanding of the instructions in the magazine and reading through Darron's build dairy, we must sand the top of the side supports nearest to the hull down until the front touches the (horizontally held) canopy.
#6 Posted : 20 May 2012 21:12:41
Hi Jonny,
I had this fit issue also. I filed the the back end away until i had a snug fit along the full join. the metal is soft so not a big problem. Just keep test fitting as you go.
Good luck Mellow
