Issue 74 - Channel mouldings Options
StefanDV
#1 Posted : 14 May 2012 12:29:55
After finishing the top yards, my next step in the build will be issue 74.
Doing some preliminary measuring, it seems that the the channel mouldings gets fitted right over the holes which were drilled for the gun-port lids.
Are the holes re-drilled at a later stage? Should there not be any holed for the upper gun ports?
Please help!
Son of Bulwark
#2 Posted : 14 May 2012 19:01:21
Hi Stefan! Cool
I think you might have jumped the gun if you have already drilled holes for the upper gun port lids. As the holes for the upper gun port lids (the first two ports from the bow & the last five ports from the stern on each side) as well as the ones for the quarter deck are done in issue 82.
These holes about 8mm above the port but below the top moulding.
Darron
StefanDV
#3 Posted : 15 May 2012 08:16:23
Thanks so much Darron.
Looks like I'll have to revert to the wood filler!
This page was generated in 0.113 seconds.
