 Rank: Pro  Groups: Registered
Joined: 07/01/2011 Posts: 399 Points: 1,212 Location: Penhill Estate, Western Cape, ZA
After finishing the top yards, my next step in the build will be issue 74. Doing some preliminary measuring, it seems that the the channel mouldings gets fitted right over the holes which were drilled for the gun-port lids. Are the holes re-drilled at a later stage? Should there not be any holed for the upper gun ports? Please help!
Hi Stefan! I think you might have jumped the gun if you have already drilled holes for the upper gun port lids. As the holes for the upper gun port lids (the first two ports from the bow & the last five ports from the stern on each side) as well as the ones for the quarter deck are done in issue 82. These holes about 8mm above the port but below the top moulding. Darron
Thanks so much Darron. Looks like I'll have to revert to the wood filler!
