56 Pages «<3132333435>»
S2ksean
#641 Posted : 12 May 2012 19:17:41
Got the second planking to do so not much progress but I'm on off for a couple of weeks starting next week so that's when I'm looking to do it.
CURRENT BUILDS
Mclaren MP4-23
HMS Pandora
#642 Posted : 13 May 2012 15:22:30
Good stuff SeanBigGrin Looking forward to seeing that.
If I can offer a tip do not second plank the sides the way the instructions say, please follow my build it is easier and more straight forwardThumpUp Regards Mike
#643 Posted : 16 May 2012 08:49:37
ISSUE 37
Hi Team this week we receive another part of Brass etch, again I was at the newsagent at 06:30:-
#644 Posted : 16 May 2012 08:53:27
ISSUE 37
I trimmed the pieces as usual and filed the burrs:-
#645 Posted : 16 May 2012 08:57:19
ISSUE 37
Then I fitted the doors with super glue gel, and bent the corner piece over the edge of the conti board, and after the part was bent I fitted the door (My advice do not fit it before):-
#646 Posted : 16 May 2012 08:59:23
ISSUE 37
Time to fit the part which I did using my clamps for 5mins while the glue takes:-
#647 Posted : 16 May 2012 09:02:14
ISSUE 37
And finally the job is done fore this weekBigGrin Questions and comments welcome
Regards Mike
StefanDV
#648 Posted : 16 May 2012 11:02:30
Very nice build and another awesome build dairy Mike!
Will the brass pieces be painted? Is there enough room to get in there with a brush/airbrush?
#649 Posted : 16 May 2012 18:35:05
Hi Stefan thanks for the nice commentsBigGrin
I believe we will be spray painting the Brass etch and in my opinion there is enough room to do this, but we need to do it before we put the deck down, or we will have to mask everything.
I will be filling all the joins with white squadron putty, otherwise we will see every join when we add paint.
Thank you for your question I hope my answer helpsBigGrin Regards Mike
mark 2
#650 Posted : 23 May 2012 06:53:22
Hi Mike.
Great build.
Wanted to ask your oppinion as i am building HMS Hood aswell. Would it be easy to fit lights on this model and what would be the best way of doing this.
Any help would be great thanks.
Best regards.
#651 Posted : 23 May 2012 15:46:54
ISSUE 38
Hi Team this is what we received this week:-
More Brass etch to clad the deck, it really is nice stuff to useBigGrin
#652 Posted : 23 May 2012 15:59:46
ISSUE 38
You know how to cut the brass out now, if not please refer to my previous postsBigGrin
I found it is very important to make sure you have taken off the burrs (where the brass part is attached to the fret) on this issue as I nearly left some on and just in time I remembered, it would have affected the fitting tolerances.
I followed the instructions and bent the brass as the visuals show (very slowly):-
#653 Posted : 23 May 2012 16:05:06
ISSUE 38
I fitted the doors with Gel Super glue, and fitted the parts with serious glue from Evo Stick:-
Yutaro HONMA
#654 Posted : 23 May 2012 16:13:44
Hi Mike!
How are you today? I guess your knife is for surgeon. It is very sharp. Sure, I also think it is very important to remove burrs from the metal parts carefully.
Best Regards,
Yutaro
#655 Posted : 23 May 2012 16:20:20
BigGrin Nice work Mike and yes those little burrs can cause a lot of problems with the fitting if not removed
#656 Posted : 23 May 2012 16:30:13
ISSUE 38
Thank you Yutaro san I am well.
Cheers Andy, for the supportBigGrin
I used my clamps to fit the brass untill the glue had dried (15 mins) I also found it essential to remove any adhesive overspill from the wood in the corners, bottems and sides, so I could get the best fit possible with the brass. and here is the finished build this week:-
Questions and comments welcomeBigGrin
budgie
#657 Posted : 23 May 2012 18:43:32
Drool hi Mike coming together nicely with those nice shiny parts(no blood stains either from the burs)
Blushing Hope you dont mind me asking
The gap between certain bulkhead sections does not look very big
so would you reccommend for people who have not reached this stage yet to join the sections of bulkheads together but NOT to glue those sections to the deck untill after brass bulkheads painted (for ease of access)or would this pose another problem
Cheers
#658 Posted : 23 May 2012 22:28:07
Hi Budgie, thank you for your kind commentsBigGrin and no blood yetBlink
Thanks for your question, in my opinion follow the instructions and stick everything down, because we are going to have to fill all the brass joins in order for the surfaces to look good when paint is applied (I will use white squadron putty)if you do not stick them down, your finish will not be goodCrying I hope that helpsBigGrin Regards Mike
harty
#659 Posted : 23 May 2012 22:59:28
Coming together nicely.BigGrin
#660 Posted : 24 May 2012 22:44:07
Hi Harty thanks for the nice commentsBigGrin Regards Mike
Guest (14)
This page was generated in 0.351 seconds.
