56 Pages «<3031323334>»
#621 Posted : 03 May 2012 14:42:38
Hi mike.
Nice clean finsh to your hull. well done on the first of many brass bulkhead walls, they get even fiddler when you have to stick doors , ventilater covers and other bits to the bulkheads.
are the portholes drilled into the wood to give them depth.
looking fantastic keep up the good work.
Ian Cool
#622 Posted : 03 May 2012 20:22:26
Thank you Ian for your kind commentsBigGrin Regards Mike
#623 Posted : 03 May 2012 20:52:11
BigGrin Looks like loads of etch to come yummyDrool , looking great MikeCool
#624 Posted : 04 May 2012 08:10:09
Hi Andy, I must say it makes a change from all that plankingBlink Its quiet refreshingBigGrin Regards Mike
#625 Posted : 10 May 2012 10:00:29
ISSUE 36
Well Team I was out bright and early this morning (06:30hrs)and got right down to fitting the parts this week.
I will not go through all the preperation stages, you will be able to pick them up on my build at ISSUE 35
This is what we received today:-
#626 Posted : 10 May 2012 10:03:08
ISSUE 36
I cut out the brass parts with a scalpel, then filed the Brass etch where the parts were attached to the fret:-
#627 Posted : 10 May 2012 10:07:36
ISSUE 36
Then I attached the doors to the brass, using super glue gel, and making sure the hinges were on the correct side.
Then I bent the brass corner piece at 90 degrees.
#628 Posted : 10 May 2012 10:12:38
ISSUE 36
Finaly I stuck the piece`s to the superstructure, in the correct position, using my prefered adhesive (evo stick serious glue)
Remember I have treated the superstructure with sanding sealer for a better bond.BigGrin
Thats all for this week questions and comments welcomeBigGrin
Kind regards
Mike
Gaz
#629 Posted : 10 May 2012 13:54:49
Hi Mike,
Your hood's looking great. Can ask how are you bending the etch parts? I have seen photo etch pliers for sale for around £25 and didn't know if these are a good idea or not. Your input would be greatly appreciated.
Gareth
Completed models,Hachette Titanic.Deags. Hms Victory. Hachette Hems Hood.Ongoing builds. Deags Akagi,Deags Sovereign of the Seas,Deags Spitfire,On my wish list.Yamato.Royal Navy world war 2 aircraft carrier.
#630 Posted : 10 May 2012 14:03:45
Hi Gareth, thank you for your question.
I am not using any special tool just two steel rule straight edges (one on the fold and one behind) to create the bend.
Also I have used the edge of the white conti board you can see in the photos.
I hope that helps. Thank you for your nice commentsBigGrin Regards Mike
#631 Posted : 10 May 2012 14:56:27
Comming along nicely mike.
look forward to the next installment Ian.Cool
harty
#632 Posted : 10 May 2012 14:57:07
It just goes to show that you can spend what ever you want up to a small fortune on tools but some of the simplest and cheapest are at hand and will do the job.BigGrin
#633 Posted : 10 May 2012 15:01:15
BigGrinThank you Ian for your nice commentBigGrin Regards Mike
#634 Posted : 10 May 2012 15:02:51
You are right HartyBigGrin What did we do before all those fancy tools? regards Mike
#635 Posted : 10 May 2012 23:38:26
Hi Mike,
Well done Mike this will look good when finished.
Reg-tf64.
#636 Posted : 11 May 2012 10:08:19
Hi Trev, thanks for your nice commentsBigGrin Regards Mike
Jesus-Belzheim
#637 Posted : 11 May 2012 17:29:42
Hi Mike
I read your Building diary of the Hood,
And it looks very good ThumpUp
Keep up the good work BigGrin
Kind regards
Peter BigGrin
HMS Victory 1:84 DeA
#638 Posted : 11 May 2012 18:27:22
Hi Peter Thank you for your nice commentsBigGrin Regards Mike
S2ksean
#639 Posted : 11 May 2012 20:14:30
Looks great so far mate
CURRENT BUILDS
Mclaren MP4-23
HMS Pandora
#640 Posted : 12 May 2012 11:57:27
Hi Sean thanks for your commentsBigGrin how is your build going?Regards Mike
This page was generated in 0.412 seconds.
