 Rank: Pro  Groups: Registered
Joined: 27/06/2011 Posts: 110 Points: 312 Location: Glasgow
Not sure if this is the best place to ask this, but here goes. I have some 0.6mm thick, Burmese teak veneer and i need to know what is the best way to apply it? Which Glue to use, is there a special technique involved? Any advice would be gratefully accepted I smile because i have NO IDEA whats going on :)
Hi Smuggler, every one will have their own preffered choice such as contact adhesive I find this can be very difficult to remove residue from your planking. I like to use PVA it does not stain, no toxic fumes and any surplus can be removed with water, and you have plenty of time to position your timber  I hope that helps you  Regards Mike MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
hi,I tend to use superglue gel,because it's thick(a bit like me)it is easily managed,you have time to fix it just so,provided you don't press it on,just slide it about until your sure of the posititioning,then PRESS DOWN,and it's stuck.just try it on scrap wood and see. Current builds: SotS, USS Consitution, San Felipe, D51 loco, HMS Surprise, RB7, Arab Dhow, Jotika HMS Victory Completed builds: HMS Pickel, Thermopylae, Mississipi river boat, Mary Rose, Cutty Sark, San Francisco II, HMS Victory x5, Titanic Lifeboat, Panart HMS Victory Launch, Hachette Titanic, Virginia Schooner, Endeavour Longboat. http://www.model-space.com/gb/
Thanks for the advice, might try the superglue route first I smile because i have NO IDEA whats going on :)
Hi Smuggler, sometimes super glue does not adhere well to untreated wood, you may have to use sanding sealer on the base planking first to seal it,  Regards Mike MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
