Beginers Air Brush Set Options
#1 Posted : 08 May 2012 23:18:34
BigGrin Hi All
iv noticed several times in various posts over the time iv been a member here that people ask about airbrushes and whats the best thing to get,also iv read and heard of the ebay so called bargains with compressors sold as new but need expensive repairs,well this is what iv just bought off the web for £75.95. Oiless silent piston compressor,Gravity feed dual action airbrush,bottom feed airbrush and 3m hose + an airbrush holder.Im sure there will be comments on this item but as a brand new item i think as a starter set you cant go far wrong.
comic123
#2 Posted : 08 May 2012 23:41:21
had my eye on this set for when payday comes have a cannister air brush and wanted to upgrade is it as good as it looks
#3 Posted : 09 May 2012 00:06:56
BigGrin I sent for it this morning at 9:00 am if you order before 12pm then its guaranteed next day delivery, the email stated it will be delivered tomorow [the 9th]il post more close up pics when i get it m8.And yes i too used the canisters for a while but that can be an expensive way to do it when your spraying a lot plus i worked out that buying this was going to be far cheaper in the long run than the tamiya spray cans of Kure grey at £7 sqid a time
Silent_Running
#4 Posted : 09 May 2012 04:11:43
Hi Andy,
You're right its a cracker. I've already logged the web page and intend to get one of these. Thanks for the info, much appreciated. BigGrin Cool
#5 Posted : 09 May 2012 09:57:05
BigGrin Your welcome Glen,glad to help and as you say well worth it as an introduction set with the option of both types of airbrush
#6 Posted : 09 May 2012 11:29:12
BigGrin Hi All
As i said to comic123 heres some pics of the kit as recieved,i had an e-mail this morning saying delivery would be between 9:50 and 10: 50 the well packaged box arived at around 10:10 am.full instructions came with the compressor and a 10% of coupon on your next purchase was also included. The airbrushes supplied are of the cheaper end of the market but i expected this, the proof of the pudding will be how they perform when used.All in all i cant fault this package as a starter kit, I have to say the the service from airbrush is excelent,all comments and questions are welcome
#7 Posted : 26 May 2012 13:35:49
BigGrin Hi
I have now used this kit several times and cant fault it for the price
PS
I forgot to mention how quiet it is too when in use
#8 Posted : 26 May 2012 13:43:40
That's good to hear, and no doubt many hours of its use ahead Cool
max50
#9 Posted : 11 December 2012 11:41:30
Hi Andy,
How are you getting on with the airbrush set after 6 months use. Is it still just as good. I see it's down to £67 now.
Mal.
Mal.
Built:
Caldercraft - HM Cutter Sherbourne.
#10 Posted : 11 December 2012 20:49:45
BigGrin Hi Mal
I haven't had a problem with the kit the set up of the bottom feed airbrush wasn't too hard after I realized that over tightening of the hose stopped the flow of airBlinkand some problems of my own making with cleaning the gravity feed airbrush the tip here I think is when you think its clean do it againLOL.
As for the compressor works perfectly every time once the preasure is set it only kicks in to maintain the set preasure so its pretty silent most of the time[its not that noisy either].All in all I would recommend it, its a good beginers set I think and quite a fast service as I received mine the next day after ordering, hope this helps
#11 Posted : 11 December 2012 21:33:26
looks good set. I have never masterd mine and my compressor sounds like a VW T2 campervan engine LOL
Gaz
#12 Posted : 11 December 2012 21:56:21
Looks a good bit of kit. Have ummed and aaah about getting myself an airbrush and this looks the biz. Will have to include this in my letter to santa BigGrin
Gareth
Completed models,Hachette Titanic.Deags. Hms Victory. Hachette Hems Hood.Ongoing builds. Deags Akagi,Deags Sovereign of the Seas,Deags Spitfire,On my wish list.Yamato.Royal Navy world war 2 aircraft carrier.
#13 Posted : 11 December 2012 23:34:56
I have been using this set for about a year,and I had trouble with the bottom feed,would only work with the low pressure hose the thin one,but the real important part is clean it,clean it,and clean it again.and be very careful when you extract the needle,the lever inside can drop out.
Gaz
#14 Posted : 12 December 2012 00:43:08
Sorry to hijack the thread but I'm not allowed under any circumstances to use spray paint indoors by SWMBO ass she not fancy Kure grey or yellow ochre wallsBigGrinI understand of course that an airbrush gives better control but would it cause me to end up sleeping with the dogBigGrinno over spray.
max50
#15 Posted : 12 December 2012 08:26:34
Gaz,
They do make mini spray booths with turntable to extract all the vapour and fumes out the window with an extractor vent.Wether the vent kit comes with it on this site, i'm not sure.
Yes Karl and Andy, i've read that most of the time taken is not the spraying but the cleaning afterwards, that's why they recomend compressors instead of cans, as you can use a lot of the air just for cleaning.
Up to now i have been looking at the spraying kits on Airbrushes.com but they have been quite expensive,and when you add spray boothes,masks and cleaners, it can add up. That's why i was looking at this kit,because it doesn't matter how expensive the kit is, it doesn't make you a good painter; only practice. ( it may help, but it's a lot of money to start out with )
Mal.
Mal.
Built:
yamaska
#16 Posted : 12 December 2012 13:44:59
I use a reasonably cheap Badger airbrush and compressor. I have to say that it makes any painting job much more satisfying and the results, even with minimal practise will be excellent right from the start. The control that an airbrush gives means that you will not get paint everywhere and Gaz your wife should not worry about paint accidents even without a spray booth.
If you can get the deal over there that has been mentioned on this thread I would not hesitate for a minute to get one. Even the cleaning is not a big chore if you go about it correctly. Acrylic paints can be easily cleaned with water and a little thinner, if you use inks then its even easier.
John
#17 Posted : 12 December 2012 15:44:48
BigGrin Hi All
Karl I got my bottom feed to work on the high preasure hose by just lightly tightening it,i found to much tightening cut off the air,as for a spray booth I got the 1 mentioned on page 2 of tool sugestions [second from bottom now]an extraction/vent kit is also available I have found it to be very good no spray mist hanging in the air when in use and the filter is very easy to clean aswell. Hope this helps
This page was generated in 0.174 seconds.
