24 Pages «<910111213>»
My build another sequel Options
#201 Posted : 07 May 2012 17:40:43
BigGrin Thank you Yaturo-san now she looks right as they sayCool
#202 Posted : 08 May 2012 22:48:02
BigGrin Hi All
now to reveal one of my major enhancments i will be adding to the Yamato its a 1/250 scale photo etch set by Gold Medal.I have to say i could only source this from the USA and you wont see much change out of £100 but its what you get that counts, railings chain and solid plus pre shaped sections and turret railings,radars type 13 and 21 ,cranes, catapults, aircraft handling trolleys,gun director details,RDF antenas,funnel cap grills,15.5 turret blast bag restrainers,water tight doors and wind direction indicators.I know that some of the etch is is already included in the build but this gives me the opportunity to pick and choose the better of the two where and when it arises.
As always all comments and questions are welcome
#203 Posted : 09 May 2012 09:25:09
Will certainly look the biz Cool
#204 Posted : 09 May 2012 09:49:09
BigGrin Thanks Mr T im quite excited about this oneCool Drool
#205 Posted : 09 May 2012 16:50:25
HiBigGrin Andy one of the best just got betterBigGrin Regards Mike
harty
#206 Posted : 09 May 2012 17:06:23
That could even be etched gold. Looks like itLove
Yutaro HONMA
#207 Posted : 09 May 2012 18:01:04
Hi Andy!
You are verrrry lucky!Laugh Because this item is very rare in Japan. Whenever I tried to buy it, they were sold out.Cursing I wish I were able to use this.Crying
I introduce additional two items for you.
pic 1 shows plank deck kit for 1/250 Yamato. It can respond to the Yamato of every situation other than Okinawa version.
Contact address is info@ms-plus.com
pic 2 shows the set of barrels kit for 1/250 Yamato.
This is sold in Amazon.com
The reason why these items have been sold in Japan is that a company that provided the model DeAGOSTINI Japan still sells the 1/250 model at this time in Japan.
Best Regards,
Yutaro
#208 Posted : 09 May 2012 19:33:53
BigGrin Thanks for the nice comments MWG ,Harty and Yaturo-san it was not easy to source the photo etch here i had to import mine from the USA also i am quite intrested in the etch thats provided with the deck kit [ i wont be using the decking as in building the okinawa version] i surmise its the individual machine guns and some other deck fittings but unfortunatly my understanding of the japanese language is nil so its hard to navigate the site to find the correct itemCrying
andyCool
#209 Posted : 29 May 2012 20:46:33
BigGrin Today i recieved two parcels/packets from the good old USA containing the etch parts iv ordered,il add a few pics to show the quality of what iv got and also the size of it[the ruler is 30cm long].The other two sets are portholes and a super detail set that has the rails around the deck hangar/aircraft area,as ussual all comments questions are welcome
#210 Posted : 29 May 2012 21:40:37
Hi Andy the quality looks greatBigGrin I like your attention to detailBigGrin Cool Regards Mike
harty
#211 Posted : 29 May 2012 21:42:07
that is one cosmic set of brassLove
#212 Posted : 29 May 2012 23:19:48
BigGrin Thanks Mike and Harty for your continuing support your comments are always apreciated
#213 Posted : 02 June 2012 14:48:00
BigGrin Hi All
finally finished adding all the portholes, degausing strip and brackets,iv also added a pic of the wire provided to make the degausing strip, glad i used the plastic strip just didnt fancy trying to straighten that lot out.Just a little filling to be done around the brackets.As usual all comments and questions are welcome
Yutaro HONMA
#214 Posted : 02 June 2012 18:37:44
Hi Andy!
Thank you for sharing the photos. They look very great and beautiful!Drool
I am now thinking about my Yamato that has already been completed. It has only 0.5mm brass wire for the cable around the hull. I may be going to replace the wire of the Yamato for enhancement some day.Cool
Best Regards,
Yutaro
#215 Posted : 02 June 2012 22:37:04
BigGrin Hi Yaturo
Thank you for the kind words if u need to know what strip i used its posted in Mr T's Yamato build diary i think its 1mm by 0.5 mm as you have said the results are more realistic to the full size as its replicating the armoured box that covered the cable,Also from reading other build diarys when i started this build i never liked the wire that was going to be used so opted for Mr T's solution
Yutaro HONMA
#216 Posted : 03 June 2012 08:35:55
Thank you for your suggestion, Andy.BigGrin I'll search the suggested articles and learn about the cable around the hull.
Best Regards,
Yutaro
#217 Posted : 03 June 2012 10:32:37
BigGrin Glad to help Yaturo-sanCool
#218 Posted : 13 June 2012 18:21:43
Angry recieved part 13 today and 2 parts missing namely the wire strip for the scuppers/eghausts.got onto deag immediatly but still means another months delay so all i have to do this month is the funnel base parts/decking
#219 Posted : 13 June 2012 19:09:18
Hi Andy you are doing a great job of this build as I have said before it is not easyBigGrin Regards Mike
#220 Posted : 14 June 2012 21:04:58
BigGrin Thanks for the support Mike i guess you can understand my frustration when things are missing from deliverys
Cool
