Bow Spirit Height Options
riff-raff
#1 Posted : 30 April 2012 21:00:53
Hi Team
How high should the end of the complete bow spirit sit off the floor when the ship is sat on its stand?
I am just at the point of adding the rigging to it but I need to know if it is in the correct position before I start
Thanks Guys
Built:
riff-raff
#2 Posted : 02 May 2012 18:49:55
Anyone? Tomick?
Built:
alantait
#3 Posted : 02 May 2012 18:59:27
sorry riff-raff not up to this point yetHuh
current builds
#4 Posted : 02 May 2012 19:53:34
riff raff,this is a hard question to answer,every ship will be different,but a good guide is when you fit the gang plank to the fo'castle and forward knights,the bowsprite when pushed into it's hole (housing)it should be just touching the curve of the gangplank,secondly at which point of the bowsprite
do you want to measure from? 1.at the base or 2.the tip? mine is at the base 203mm. and at the tip it is 470mm.
the measurements are with the ship in it's stand and from the base of the stand.
riff-raff
#5 Posted : 02 May 2012 20:10:41
Thanks Carl - Mine is 405mm from the bottom of the base to the very tip of the complete bow spirit assembly
I just needed to know if it was sitting at more or less the right angle to the deck.
Built:
Son of Bulwark
#6 Posted : 02 May 2012 21:20:25
Hi riff raff! Cool
The bow sprit is set at an angle of about 30 degree's to match the slope of the false keel.
Darron
#7 Posted : 02 May 2012 21:52:04
Sorry riff raff yor post slipped me by. Darron is correct in that the bowsprit angle/height is set by it resting on the angle of the false keel beneath the bow deck.
riff-raff
#8 Posted : 06 May 2012 22:42:44
Thanks Guys - I just wanted to check the correct position before I moved on to other areas.
Built:
This page was generated in 0.101 seconds.
