24 Pages «<89101112>»
My build another sequel Options
#181 Posted : 28 April 2012 18:26:20
BigGrin Thank you MikeCool
#182 Posted : 28 April 2012 21:51:54
BigGrin Hi all
I managed to get all the front section portholes/blanks compleated with the suplied blanks [hope theres more to come so i can finish the stern areaBlink ].Next will be to add the degausing strips to the hull as ussual all coments and any questions are welcome
#183 Posted : 29 April 2012 12:58:36
BigGrin Hi all
some progress on the degausing strips now 3 parts finished ,i will have to wait till i get the next issues porthole blanks to finish the stern area . As ussual all comments and questions are welcome
#184 Posted : 01 May 2012 23:46:43
BigGrin Hi All
Another enhancment im adding is the fixing straps to the armoured degausing trunking, to do this i used staples cut in half then bent over a 1mm thick steel sheet to get the desired shape.To obtain the spacing im using an unused plank cut to size to drill small holes either side then the straps/staples are pushed home[probably way out of scale but its the look im after].It will take me a while to do but as my Akagi shipment went missingCrying in the post this month and iv had to reorder iv got plenty of time.All in all i think its improved the look of this area,as ussual all comments and questions are welcome
#185 Posted : 02 May 2012 09:13:32
Going the whole hog Andy...She will look great when complete Cool
#186 Posted : 02 May 2012 21:52:41
BigGrin Thanks Mr T , there are more enhancments planed they will be added in the futureCool
#187 Posted : 02 May 2012 23:04:24
Great job AndyBigGrin Regards Mike
#188 Posted : 02 May 2012 23:25:23
BigGrin Thanks MikeCool
harty
#189 Posted : 03 May 2012 01:10:02
Looking great and you have captured a very sleek look. Great jobCool
#190 Posted : 03 May 2012 20:48:33
BigGrin Thank you for the kind words HartyCool
#191 Posted : 05 May 2012 15:14:50
BigGrin Just a few pic,s of the bow/ midships with the brackets added,bit of filler to go on in places but overall the desired effect has been achieved i think.The stern area will be finished when i recieve the next issue, as ussual all comments and questions are welcome
Yutaro HONMA
#192 Posted : 05 May 2012 17:11:44
Hi Andy-san
The surface of the hull is very beautiful! Especially this code looks like a genuine article. I like it very much!Love
Best Regards,
Yutaro
#193 Posted : 05 May 2012 18:56:28
BigGrin Thank you Yaturo-san for the kind wordsCool
Smuggler
#194 Posted : 05 May 2012 22:39:34
Stunning looking model so far, absolutely love the smoothness of the hull.Drool
It is obvious the hull was a labour of love.
Only hope my hull can be that smooth.BigGrin
No doubt when its finished, it will be a work of art.
I smile because i have NO IDEA whats going on :)
harty
#195 Posted : 05 May 2012 23:14:17
Cool Love Cool Love Love Love
#196 Posted : 05 May 2012 23:15:36
Blushing Thanks Smugglerand Harty for the kind words,believe it or not but there are some parts of the hull im not compleatly satisfied with but perhaps im being too fussy.Im sure your hull will look just as good if you follow the tips iv added in the diary.Its the initial preparation to the hull that will make all the diffrence.The 1st coat of primer will show up any major blemishes that need filling then sand that back,also spray putty helps fill any small blemishes that appear.Forgive me if im teaching you to suck eggs as they say.
Also the additional etch kit im getting will make a diffrence but more on that when it arives,again thank you for the comments they make doing a diary all the better.
#197 Posted : 07 May 2012 14:35:51
BigGrin Hi All
Another small enhancement added but 1st why i did it,in the official build the hawse pipe is represented by a piece of shaped wire but Mr T substituted a 7m plastic part made by himself.This although a good substitution it was never going to look right in my eyes so this is my solution.
Firstly i stuck four pieces of left over planking[2 by 5mm] together to form a plate[20mm by 65mm],then i drilled two 7mm holes through it.After that i marked the outer circle onto the wood and cut out both blanks.I then used sand paper and my dremel type drill to shape the pieces to the profile i wanted.
I had to do a little triming at the top as the degausing strip was slightly in the way[ on the full size Yamato the d/strip went round/followed the contour of the hawse pipe]but after some more shaping it fits quite well and now in my eyes looks more realistic.The parts were sealed and have only had a coat of undercoat so far.As ussual all coments questions are welcome
Yutaro HONMA
#198 Posted : 07 May 2012 15:45:21
Hi Andy!
I also support your reconstruction of the hawse pipes.Laugh
I send you a material that is a picture of the hawse pipe in 1/10 the YAMATO model in Kure YAMATO musium, but I was not able to judge if the hawse pipe was an ellipse or a circle.
Next pictures shows the hawse pipes of my Yamato model. They were made of putty. Although I did not have a strong evidence, I selected ellipse then.
Even if the hawse pipe is an ellipse or a circle, I recommend you not to remove the part of it because I have indicated the first picture.
That is my comment.
Best Regards,
Yutaro
#199 Posted : 07 May 2012 16:45:32
BigGrinHi All
after posting the last pics i decided that the hawse pipe still didnt look right[and as Yaturo-san has pointed out]so a small amount of reshaping has taken place at the top end, looks better now i think still needs a little finishing
Yutaro HONMA
#200 Posted : 07 May 2012 17:01:29
HI Andy!
Great! Love I'm very surprised at your prompt work!
Best Regards,
Yutaro
This page was generated in 0.264 seconds.
