Nice tip matey Thanks “Whenever you find yourself on the side of the majority, it is time to pause and reflect.” -Mark Twain
Hi Stafan. Fantastic build keep up the good work. nice tip for the cross tree Ian Current builds.Hachettes build the bismark,HMS Victory, HMS Hood. Finished Builds Corel HMS Victory cross section.
 Rank: Pro  Groups: Registered
Joined: 07/01/2011 Posts: 399 Points: 1,212 Location: Penhill Estate, Western Cape, ZA
Thanks gents, I'm busy building the fore-mast, but the pictures look so similar to the main mast, I'm not putting them up.
Quick snapshot of my progress to date: The top gallant fitted to the fore mast. There is still some painting to be done and then the mast will be dressed.
Looks like a damn good job done there Stefan....I'm at about the same stage as you mate...keep the pictures coming...
Thanks Jonny. It's a bit of a battle to make enough time to do it, but a little every evening after the boys have been put to bed does the trick for me.
The foremast painted and being dressed:  Both masts fitted (not glued) to the hull  Overall view  Fore yard being shaped  Fore yard painted  Fore yard and studding sail booms
Looking real great Stefan!! See that the captain is ready to repel all boarders!! Current Builds: Deagostini HMS Victory: Deagostini HMS Sovereign of the seas. Completed Builds: Del Prado: HMAS Bounty: Hachette: RMS Titanic: Del Prado: Cutty Sark...
Good looking job there, Stefan, you are coming on in leaps and bounds. You can be proud of what you have achieved so far. Rgds, Hans "It's okay to make mistakes. mistakes are our teachers - they help us to to learn, even if it is painfully" Current Build: Endeavour Cross section,D51 Completed: HMS Victory Under the bench: Endeavour x 2,Sovereign of the Seas, Akagi and The Black Pearl!HMS Victory Cross Section
Hi Stefan, Great work, love the detail  Regards Mike MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
Thanks Gents! Yes Jonny, through the years he has been known by many names. Diablo Gato, The Furry Lover, Chupa Cabra, Frisky Two Times and then The Gingerhead man. Don't know how he commandeered the vessel :o
Hi Stefan, Super build Stefan,all that hard work has payed off,please keep sending pictures. Regards tf64. Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
Thanks tf64! I'm rolling on the fore main yard assembly, got all the sub-assemblies done: The blocks  The wires  And then the assembly process:  And the sorting out of unforeseen issues :(
Hi Stefan, Fore main yard assembly is looking good,nice work,those sub-assemblies look hard work how's your fingers bet they sore. Not up to that stage yet,keep sending Stefan. Regards tf64. Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
 Rank: Semi-Pro Level 2   Groups: Registered
Joined: 10/01/2011 Posts: 91 Points: 273 Location: South Africa
Awesome work Stefan Keep up the good work
Thanks tf64 & Gerrit tf64: I used the rest of the wire that was supplied with the main yard which was a little tougher to wrap, but did not break at all - normal needle-nose pliers. The wire which was supplied with the fore yard was softer and more pliable, but I broke 1 while forming it and another when I fitted it to the yard I drilled another hole right next to the broken shaft and fitted another part. I'm going to ask for a replacement issue as issue 71 was short 1 of the end-irons anyway. Cutting the short pieces for the Main top yard  Middle part of the main top yard glued in place  The fore yard being dressed:
Nice and neat job there Stefan. Looks like I might need to source some better wire locally as I should be starting my masts this weekend. Rgds, Hans "It's okay to make mistakes. mistakes are our teachers - they help us to to learn, even if it is painfully" Current Build: Endeavour Cross section,D51 Completed: HMS Victory Under the bench: Endeavour x 2,Sovereign of the Seas, Akagi and The Black Pearl!HMS Victory Cross Section
Thanks Hans. It may be helpful, even though there is more than enough wire supplied. Some folk annealed their wire by heating it (may on the braai?) and then letting it cool. It would be great if you can get enough wire to finish all the yards in one go.
Joined: 05/09/2010 Posts: 123 Points: 358 Location: Valhalla, Pretoria
Hi Stefan I am enjoying your build. Speaking of wire - go and take a look at the Craft shops that sell beads to make jewelry, they have a lot of brass wire in different sizes, I found some at the china mall in JHB. Cheers Current Build: HMS Victory
Built: HMS Bounty
Next Build: Sovereign of the Seas Started collecting. Redrawing of plans for Santisima Trinidad for a scratchbuild. Santisima Trinidad - waiting for launch.
Thanks Stefan. I recall there was thread about it. Castos has also put another idea through (thanks Castos), as I am in JHb I will go and have a look anyway. You are right, there probably is suficient wire, but if the quality is suspect it will do no harm in trying to source something better. After all the money spent so far anyway, it will be worth it. Rgds, Hans "It's okay to make mistakes. mistakes are our teachers - they help us to to learn, even if it is painfully" Current Build: Endeavour Cross section,D51 Completed: HMS Victory Under the bench: Endeavour x 2,Sovereign of the Seas, Akagi and The Black Pearl!HMS Victory Cross Section
Guest (5)
