lack of clarity in issue 95 Options
spigs
#1 Posted : 24 April 2012 20:35:01
Rank: Amateur level 2
The details for adding the futtock stave deals only with the foremast. What is the length for the main mast? (40mm appears way too short) also the length of the wire provided in issue 90 is insufficient to complete the job. Were further lengths supplied in another issue ?
Son of Bulwark
#2 Posted : 24 April 2012 22:29:08
Hi Spigs! Cool
You have a shortage of brass wire, I found the same mate! the wire supplied for the futtock staves isn't enough for the job. I had to get some 1mm brass rod from the model shop and used this instead of the brass wire from the magazine, I found it was stronger and didn't bend easily and I made the staves 50mm long for the main mast, this helped when tying the brass to the shrouds as the knots didn't keep slipping off the ends of the brass rod.
Take a look in your leftover supplies, you might be lucky and find some brass wire that you can use, short leftover lengths over 25mm can be used on the mizzen. This would leave the longer length for the foremast and the main mast.
I hope this helps.
Darron
spigs
#3 Posted : 25 April 2012 10:51:18
[quote=Son of Bulwark]Hi Spigs! Cool
I hope this helps.
Darron
[Thanks for your response Darron.Guess I will have to schlep down to the DIY store to see what's on offer. Just my luck that the rain lashing down is of biblical proportions !]
Trotsky
#4 Posted : 25 April 2012 12:03:42
Don't you just love "Yiddish"
H.M.S Victory
H.M.S Victory X Section
H.M.S Surprise under the bench
D-51
This page was generated in 0.103 seconds.
