ISSUE 60 Hi Team in this issue we received Stern transom (two pieces),300x4x4mm ayous wood strip, 300x5x5mm ayous wood strips, pully wheels and Rigging blocks (4mm). The Transom shows 5 windows, but the real ENDEAVOUR only had 4, the centre one was not a window because it was over the Rudder.Parkinsons drawings show this in the Anatomy of the ship  Regards Mike MWG attached the following image(s): MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
Hi Team, I have purchased a lovely piece of Mahogany 1 metre long 2mm thick, I will be using this instead of the tacky ply to make the companion ways and covers on deck  Regards Mike MWG attached the following image(s): MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
ISSUE 61 This week we received the following parts:- An oven flu Pulley wheels Bow gunwale (three pieces) 300x5x1mm ayous strips x6 300x6x1mm ayous strips x2 300x5x2mm ayous strips x4 Regards Mike MWG attached the following image(s): MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
ISSUE 62 And in this edition we received:- Breakwater (6 pieces) Raw cotten thread (0.15mm) Rigging blocks (4mm) Belaying cleats 300x4x4mm ayous strips Regards Mike MWG attached the following image(s): MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
HULL COLOURS As you all know from my previous posts I have been looking at a different medium to colour the second planking than paint and I chose ink,Ink in my opinion shows the grain much better than paint, I published the Orangy yellow colour some weeks ago, now I have found the blue for the planks below the gunwales.It is Rowney Acrylic Rowney Blue For the Wales and anchor linings I will use black ink. I may use ink for all the deck fittings, but I have not made up my mind yet.  comments and Questions welcome. Regards Mike MWG attached the following image(s): MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
 Rank: Pro  Groups: Registered
Joined: 17/03/2010 Posts: 301 Points: 941 Location: fife
cheers mwg, will head to town for this colour of ink, it certainly gives a better finish than the paint option. regards alan current builds
Thanks for your comment Alan, when you see the ink on the ayous wood the effect is outstanding  Regards Mike MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
ISSUE 63 Hi Team this week we received Windlass gear (metal) Windlass large winch (metal) Windlass small winch (metal) these parts are better quality. Also received Pulley blocks(4mm) Rigging blocks (4mm) and the Windlass, (six pieces in wood). I will now be starting the second planking  Comments welcome. Regards Mike MWG attached the following image(s): MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
ISSUE 64 This week we received the following this week:- The small Windlass winch cast alloy The large Windlass winch cast alloy The ships Bell brass The Belfry cast alloy The Windlass Figures and dead eye blocks (7mm) Regards Mike MWG attached the following image(s): MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
ISSUE 65 Last week we received the following:- Taffarel leaf decorations and stern windows. Eyebolts 300x2x2mm ayous wood strip Brass wire (1.5mm diameter) Tiller bridge and hatch cap (nine pieces Regards Mike MWG attached the following image(s): MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
STERN MODIFICATION Hi Team I decided to change a few things with the stearn of the ship, as you know I have the Anatomy of the ship Endeavour, the vessal did not have 5 windows at the rear, only 4 windows,and the centre was covered by woodwork as it covered the Rudder Tunnel and was a sham. First up I made two new stern pieces from my Mahogany I had purchased and cut holes through the wood so that the windows when fitted would have depth:- MWG attached the following image(s): MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
STERN MODIFICATION Next I retained the stern front plate and fitted the windows at the rear of this plate (It is a good idea to retain the brass lugs on the window frame for fixing on the plate, otherwise they may fall through):- MWG attached the following image(s): MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
STERN MODIFICATION So now the windows from the front have depth. Next we prepare the centre sham, I cut a piece of Mahogany and fixed it into the rear, and taking the centre window I cut out all the spars and fitted the remaining window frame in the centre:- MWG attached the following image(s): MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
STERN MODIFICATION I had some brass beading and I decided to use this instead of wood battons,I think it looks better and more authentic:- MWG attached the following image(s): MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
Joined: 29/03/2010 Posts: 190 Points: 512 Location: Lytham UK
Hi Mike.. The Endeavour is looking great. Best regards, Ian Ian Builds in progress: E-type, HMS Victory, HMS Endeavour, HMS Soverein of the Seas Wish list: Bentley Blower http://forum.model-space...spx?g=posts&m=30439
http://mxpublishing.co.uk/engine/shop/product/9781780920184/Hunt+for+the+Blower+Bentley
STERN MODIFICATION Well Team here is the finished result,I do not know if I will use blue on the stern or just varnish it. The beading has to be trimmed and permanently fixed. also I will fit acetate behind the windows maybe yellow Thanks for looking Questions and comments welcome  Regards Mike MWG attached the following image(s): MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
Excellant little tip that about keeping the lugs on. Good call.
Love what you have done Mike...All good stuff mate!!  Current Builds: Deagostini HMS Victory: Deagostini HMS Sovereign of the seas. Completed Builds: Del Prado: HMAS Bounty: Hachette: RMS Titanic: Del Prado: Cutty Sark...
Hi Mike, i think that this looks alot better, just what i was thinking about doing, as for the acetate i think that might work depending upon how transparent it is with no real interior. no doubt i will find out when i finally get to doing this myself regards current builds
Thank you, Harty, Jonny and Alan for your nice comments, much appreceiated  Regards Mike MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
Guest (6)
