Plank ! Options
Skiddy
#1 Posted : 18 April 2012 16:21:53
Trying to keep off the 'RED' subject Cursing at the moment and I assume there is no underfloor plank to fit to this model.
I have looked at various places regarding this build and cannot find any info or a mention....so I guess if we want one we will have to make one.
#2 Posted : 18 April 2012 16:49:22
An interesting subject, 'the plank' was introduced in 1994 to provide a minimum ride height for F1 cars after the events of Imola that year. This was the end of the flat floor and the birth of the complicated stepped floor.
I'll ask the question..
In the meantime for anyone that wonders what the plank is for..
Ride height control is needed to maximise the performance of the underfloor aero. It's ride height control that the teams need in order to maximise performance.
Ride height control is used by the FIA to limit the performance of the underfloor aero, and in effect its a passive safety feature.
One of the problems with the old flat bottomed cars was that in certain conditions they could very quickly go from creating huge downforce to none at all, and if the speed was high, the car then became a missile and headed straight for an accident and it be huge.
andyone
#3 Posted : 18 April 2012 17:40:47
Rank: Amateur level 2
F1 regulations heavily limit the use of ground effect aerodynamics which are a highly efficient means of creating downforce with a small drag penalty. The underside of the vehicle, the undertray, must be flat between the axles. A 10 mm thick wooden plank or skid block runs down the middle of the car to prevent the cars from running low enough to contact the track surface; this skid block is measured before and after a race. Should the plank be less than 9 mm thick after the race, the car is disqualified.BigGrin
Skiddy
#4 Posted : 18 April 2012 18:05:51
Thanks Tomick and andyone, very well said and well informed...
but just wondering is there one included Unsure
I'm sure Tomick will find out.
1:8 scale must be just over 1mm thick then OhMyGod
only1ianuk
#5 Posted : 18 April 2012 18:59:39
Check part number 65 on the japan site. It's in the parts list. I would post the picture but then Tomick would shout! LOL
I'm sure thats what you mean?
http://translate.google....bih%3D744%26prmd%3Dimvns
#6 Posted : 18 April 2012 19:36:51
BigGrin LOL looks like a proper plank to meLOL LOL BigGrin Cool
#7 Posted : 18 April 2012 20:14:14
Looks like query solved and thanks to Ian for spotting it Cool
schueyking
#8 Posted : 18 April 2012 20:25:33
I am afraid you are wrong guys,,,,that is Kimi's Ice cream stick!!!!LOL LOL LOL
Skiddy
#9 Posted : 18 April 2012 23:59:23
[quote=only1ianuk]Check part number 65 on the japan site. It's in the parts list. I would post the picture but then Tomick would shout! LOL
http://translate.google....ih%3D744%26prmd%3Dimvns[/quote]
ThumpUp
noki49
#10 Posted : 19 April 2012 22:27:17
I am worried by some of the articles in the link regarding some butchering required to make some of the of the engine cowls fit properly.Sad
PhilE
#11 Posted : 20 April 2012 13:47:56
Also notice there was a mention there of a clear coat to achieve a glossy finish? Is that the fix for the colour mis-match?
bigmal0
#12 Posted : 20 April 2012 20:26:00
Could you tell me where the colour miss match is please
PhilE
#13 Posted : 21 April 2012 22:32:56
There is a note on the Japanese site here, second item in the list, about using a clear coat for the model, although the translation is difficult to read.
Was just wondering if this clear coat is just protection or if it has anything to do with the Colour change in parts OMG thread.
#14 Posted : 21 April 2012 23:20:36
Can I gently remind members to place posts which relate to the colour finish, into the existing finish topic
http://forum.model-space...s&m=48068#post48068
Thankyou
