3 Pages <123>
Fire Buckets Options
Quintin
#21 Posted : 17 April 2012 20:17:59
I used a craft knife for shaping and a ground down welding rod to drill the buckets out BigGrin
Part time modeller, full time biker
Built: Pinta
Belle Poule (plastic)
Endeavour
Scratch build of Pirate ship "Neptune" (Based on cutter "HMS Aldebaran"
Current builds: Victory
Mr.Quist
#22 Posted : 17 April 2012 21:38:58
RussG wrote:
Hi well apart from making them if you have the tools, Cornwall Model Boats have a wide choice from 22p on!!BigGrin
That looks good. Anybody having an idea what the right size would be ??
Cheers, Timm
My build diary here
HMS Victory
willie
#23 Posted : 17 April 2012 22:38:46
Cheers, Timm
is this the fire buckets you mean these are 3mm dia 3mm tall home made
jeff averre
#24 Posted : 17 April 2012 23:00:42
I got some of these a while ago from 'Cornwall mb', they are from Amati Fittings and are 3mm brass cannon buckets, they are the nearest to the size we require all the rest are far to big.
There are no handles so we will need to sort that out, but I don't think that will be a problem.
Jeff
DavidM
#25 Posted : 18 April 2012 16:43:24
Rank: Beginner Level 3
hi Jeff i am a palm reader and i see many great things in your life just by reading your palm it is showing you have much love in your life this has nothing to do with that wedding band i also see you were once a great ruler in your past life you also never let tiny things get in the way of success if you would like me to do more readings for please send me a message
RussG
#26 Posted : 18 April 2012 19:04:50
Jeff
Cheers for that Jeff, Think I Might get some ordered!BigGrin
Happy Building, Russ
On the workbench: My Victory Build Diary - Victory Cross Section Build Diary - Black Pearl Build Diary
Under the Bench: Millenium Falcon, Black Pearl x 2, Coral Victory Cross Section, De Lorean
jeff averre
#27 Posted : 19 April 2012 00:03:15
Nice one Dave,
I still am a ruler, in my house (don't tell the missus though)
You'd better not tell her of all the other 'Loves' in my life either!
LOL LOL LOL
Jeff
GilShapley
#28 Posted : 22 April 2012 15:33:06
I have had a go at making some buckets of my own, we need about 20 according to pictures on the Victory web site.
Could use those mentioned already as provided by Cornwall Models but I like a challange, so here goes. Feedback as always is welcombe and any suggestions for improvement.
It occurred to me that the bucket shape is similar (roughly) to an air gun pellet (.177) and these are made of soft lead so easy to work with.
Step 1
You will need a former, I made a simple one from a round nail with the point removed and I shaped the end with my dremil grinder.
Step 2
Using a small (Tack) hammer attatch the pellet to the end of the nail and hammer it into shape rolling it along the bench as you go until the shape is as required, Mucked up a few but at £5 for 500 you can get plenty of practise.
When you have the required shape, I sanded the bottom to make it flatter
and a bit smaller, drill two small holes for the handle. I made the handle from a single strand of 13 amp wire, it is very soft and again easy to work with.
Finally paint it black.
Still thinking about adding the lettering and date. Dont think my eyes are good enough or my hands steady enough
No two buckets are the same and I think this adds to the effect as the original where made of leather and must have been all shapes.
Not sure what to use for the sand to fill the buckets, any suggestions
Current Build:-
GilShapley
#29 Posted : 22 April 2012 15:36:17
Second picture attatched. For some reason it did not load the first time
Current Build:-
GilShapley
#30 Posted : 22 April 2012 15:38:58
Third time lucky
Second picture attached
Fire Buckets.jpg (270kb) downloaded 139 time(s).
Current Build:-
jeff averre
#31 Posted : 22 April 2012 22:46:47
Excelent job there Gill,
I'm sure I've got some of those 'slugs' knocking about in the garage, I think I'll give it a go!
Jeff
Glen
#32 Posted : 24 April 2012 15:01:09
Fantastic Idea, I will have ago at thatBigGrin
Roger the Cabin Boy
Glen
#33 Posted : 24 April 2012 15:06:47
Concerning the sand to fill the buckets with, my local Antics model shop has small bags of sand for this purpose, quite cheap as well.Laugh
Roger the Cabin Boy
GilShapley
#34 Posted : 24 April 2012 18:07:28
Well I thought you might like to see how I got on
some 20 buckets later
I have tried to create some transfers to add the GR logo but the scale seems to be too small. Whilst I can create some transfers once attached to the buckets they are not readable so I think I will go without.
I have modified my original plan to make the buckets more conical. More in line with the pictures I have seen of the original buckets.
Only have to figure a way of attatchment. Still will be walking the decks of HMS Victory,Camara in hand, next week. So that hopefully will give me some ideas
As always sugestions will be welcombe
Current Build:-
#35 Posted : 24 April 2012 18:20:31
Great work Gil ThumpUp
#36 Posted : 25 April 2012 07:59:51
Hi Gil awesome jobBigGrin Regards Mike
#37 Posted : 25 April 2012 09:55:25
Hi Gil,
Took this photo of the fire buckets last week,I counted 21,hope this helps you with your project.
Regards tf64.
#38 Posted : 25 April 2012 09:56:31
Hi Gil,
Regards tf64.
#39 Posted : 25 April 2012 10:11:58
BigGrin Trev, you are correct it is 21 bucketsBigGrin Regards Mike
#40 Posted : 26 April 2012 14:52:31
hi all can you spot the bucket Gil made in post 30,I think it is number 5 in the line up on gil's post 34?.
Great job Gill look's exceptional.
Regards tf64
3 Pages <123>
This page was generated in 0.215 seconds.
