 Rank: Pro  Groups: Registered
Joined: 31/03/2010 Posts: 194 Points: 446 Location: Gloucestershire
`Hi all, I don't know if this has been covered before but, are we going to get the fire buckets that hang down from the Poop deck. I would have thought they were there at the battle of Trafalgar. Or do we have to find somebody who can make them atthe right scale? Roger the Cabin Boy
hi glen,I have been thinking about the buckets my self,bear in mind that they were made of leather,so I might make them up from either card or plasti-card.and have a bash at making up decals to do the G & R. Current builds: SotS, USS Consitution, San Felipe, D51 loco, HMS Surprise, RB7, Arab Dhow, Jotika HMS Victory Completed builds: HMS Pickel, Thermopylae, Mississipi river boat, Mary Rose, Cutty Sark, San Francisco II, HMS Victory x5, Titanic Lifeboat, Panart HMS Victory Launch, Hachette Titanic, Virginia Schooner, Endeavour Longboat. http://www.model-space.com/gb/
This image might help for reproduction, which is of a genuine 1803 Victory fire bucket Tomick attached the following image(s):
Hi Karl, So i take it we will not be getting them? That's a lot of buckets to make, what is it, around 16-20 something like that. Roger the Cabin Boy
They are not shown in any images of the model so one can only presume not.
I have a photo of the the current G&R on the black back ground. If you scale down and print that should do the job for the logo. there may be some after marcket buckets available? “Whenever you find yourself on the side of the majority, it is time to pause and reflect.” -Mark Twain
Hi Mald if there are to be no buckets with the series, I have a source for these  Regards Mike MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
Joined: 27/01/2012 Posts: 28 Points: 84 Location: Netherlands
Hi Maldbuild, I like to have firebuckets too. I tried to make one from paper as follows: Roll a peace of paper as a bag with a sharp bottom. (Of cause with som glue).  When dry, cut the bottom where it is 2 or 3 mm wide and a bit higher where it is 5 mm wide. Glue a bit of paper at the bottom (You don't want a hole in the bucket) and paint the whole black. With a peace of black thread you can create a handle. It takes only a few minutes for one.  Jan Zwart janzwart attached the following image(s): Current build: HMS Victory Already built: Half moon, Stadt Bremen.
Sorry the wrong foto. This one shows the paper bag. Jan Zwart  janzwart attached the following image(s): Current build: HMS Victory Already built: Half moon, Stadt Bremen.
Thanks fellow builders , I will try the paper trick ,Mike can youy let me know how I can get some please. Regards mald
Hi Mald if the series does not have buckets I will post a thread on the buckets  Regards Mike MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
Thanks Mike
I am going to see what mike can pull out of the hat as making the fire buckets will be a right pain plus you need handels to hang them and hangers for the rail Mike do your stuff mate!!!! please “Whenever you find yourself on the side of the majority, it is time to pause and reflect.” -Mark Twain
Hi Mald and Jase, I will only press the button on this item ,If there are no Fire Buckets in the series, but I am ready  Regards Mike MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
Hi All, I have had a go at making Fire Buckets. I used 5mm dowling, first drill a 4mm hole into the dowling only a couple of mm's, then a craft knife to shape and cut off 6-7 mm it only takes a few mins to do, then paint black.Add details i.e Crown, HMS Victory and date 1803 with a steady hand and magnifiing glass it can be done. Make a thick handle from rigging yarn and super glue inside the bucket and fill with sand,looks quite good. Roger the Cabin Boy
Glen wrote:Hi All, I have had a go at making Fire Buckets. I used 5mm dowling, first drill a 4mm hole into the dowling only a couple of mm's, then a craft knife to shape and cut off 6-7 mm it only takes a few mins to do, then paint black.Add details i.e Crown, HMS Victory and date 1803 with a steady hand and magnifiing glass it can be done. Make a thick handle from rigging yarn and super glue inside the bucket and fill with sand,looks quite good. Got a pic mate? “Whenever you find yourself on the side of the majority, it is time to pause and reflect.” -Mark Twain
Hi Jase, Sorry mate i have not got a camera yet, Itried plugging my Box Brownie in but it won't work, for some unknown reason it will not upload the pictures. If you just drill into a piece of dowling you should see what i mean the bucket is half made then shape with a knife the cut off. If you know any one who will make the buckets for us like the wheel etc i would be interested. Roger the Cabin Boy
Joined: 08/09/2010 Posts: 102 Points: 318 Location: Durban, South Africa
I used the dowell method to make the fire buckets for my son's pirate ship, it was quite effective, and only took about 20 mins a bucket. Fortunately I only needed to make 7 for that model, so didn't take too long. Part time modeller, full time biker
Built: Pinta Belle Poule (plastic) Endeavour Scratch build of Pirate ship "Neptune" (Based on cutter "HMS Aldebaran" Current builds: Victory
Joined: 20/03/2010 Posts: 462 Points: 1,299 Location: Tortuga !
Hi well apart from making them if you have the tools, Cornwall Model Boats have a wide choice from 22p on!! Happy Building, Russ On the workbench: My Victory Build Diary - Victory Cross Section Build Diary - Black Pearl Build DiaryUnder the Bench: Millenium Falcon, Black Pearl x 2, Coral Victory Cross Section, De Lorean
