56 Pages «<2829303132>»
Silent_Running
#581 Posted : 14 April 2012 22:42:01
Looking good Mike, awesome job ThumpUp
#582 Posted : 15 April 2012 11:20:07
Hi Glenn thank your for the encouragementBigGrin Regards Mike
#583 Posted : 16 April 2012 23:08:07
Hi Team, further work coating the inside of the HullBigGrin Regards Mike
#584 Posted : 16 April 2012 23:10:44
ISSUE 32
We received more planks for the second plankingBigGrin Regards Mike
#585 Posted : 20 April 2012 19:27:41
ISSUE 33
We received more planking for the second sheathingBigGrin Regards Mike
#586 Posted : 20 April 2012 19:35:12
SECOND SHEATHING
Hi Team I am just completing ISSUE 29 BigGrin Here are some photos:-
Regards Mike
#587 Posted : 20 April 2012 19:46:33
SECOND SHEATHING
Here you will see I have started the second planking, some of the planks are thinner than others but this will not be a problem as we will be sanding again when the planking is finished.BigGrin Prepare your first planking by sanding and shapeing well.
Please make sure you step the planking as in my Photos, and use pins with PVA, to fit the planks, the PVA is easy to wipe off the wood ,contact adhesive is to messy and not easy to wipe off, and the vapours are not good if someone in your family is asphmaticBlink
Regards Mike BigGrin Comments and Questions welcome
#588 Posted : 20 April 2012 21:51:21
BigGrin The secondary planking will make all the diffrence both in strength and looks, enjoying this build Mike looking good
#589 Posted : 21 April 2012 11:38:52
Thanks Andy for your commentsBigGrin I will be second planking in a different sequence to the instructions I will explain laterBigGrin Regards Mike
#590 Posted : 22 April 2012 12:32:01
SECOND PLANKING ISSUES 29 to 33
Hi Team,
Here are more photos of the second planking. Please notice the stepping of the planks, we also need to bevel the planks so that each plank butts up to each other as the planks go around the Hull and curved parts.
When I started the second planking at the rear (as per the instructions)I then ignored the sequence in the instructions and planked the whole starboard side in one go, made much more sence to meBigGrin Have a look:-
Regards Mike
PS I chose to use lots of pins to fix the planks with PVA adhesive. Please note if you use this method you must fill in all the pin holes before sanding as all blemishes will be seen, it is more important on the second planking than on the first.
I believe the fixing you get with the pins is worth the extra workBigGrin Questions and comments welcomeBigGrin
Gaz
#591 Posted : 22 April 2012 15:30:38
Looking good Mike. Agree with you regarding pins this what i'm doing also.
Gareth
Completed models,Hachette Titanic.Deags. Hms Victory. Hachette Hems Hood.Ongoing builds. Deags Akagi,Deags Sovereign of the Seas,Deags Spitfire,On my wish list.Yamato.Royal Navy world war 2 aircraft carrier.
#592 Posted : 23 April 2012 07:22:26
Hi Gareth, Thank you for your nice commentsBigGrin Regards Mike
#593 Posted : 23 April 2012 21:26:37
BigGrin looks good Mike and i would have planked the same way u have too Andy
#594 Posted : 23 April 2012 21:27:26
SECOND PLANKING 29 to 33
Hi team this is what she looks like,with the Starboard side completely fitted with the second planking and all the pins removedBigGrin Questions and comments welcomeBigGrin Regards Mike
#595 Posted : 23 April 2012 21:31:44
Hi Andy thanks for the vote of confidenceBigGrin Regards Mike
#596 Posted : 23 April 2012 21:41:35
Looking good Mike, and not a voodoo doll in sight LOL
#597 Posted : 23 April 2012 21:43:30
Thanks Mr T for the words of encouragementBigGrin much appreciated.
Regards Mike
#598 Posted : 23 April 2012 21:46:31
Soon be onto the deck goodies Cool
#599 Posted : 25 April 2012 23:31:02
Tell us more MR TBigGrin Regards Mike
#600 Posted : 26 April 2012 14:57:06
Looking fantastic mike.
keep up the good work. mines being stored away at moment for a future build as the bismarck needs finishing and the victory is on the go.
catch you soon ian BigGrin
Guest (12)
This page was generated in 0.294 seconds.
