ISSUE 28 AND 29 At this point I revisited the Bow and trimmed the edges of the deck back to the ribs. I was then able to fit properley the bow side panels we received in ISSUE 28 I will be using screws wit adehsive to fix the decks down. questions and comments welcome  Regards Mike MWG attached the following image(s): MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
Looking good mike. like your extra deck support idea ian. Current builds.Hachettes build the bismark,HMS Victory, HMS Hood. Finished Builds Corel HMS Victory cross section.
Thank you for your nice comment  Regards Mike MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
Looks like some great building going there Mike. Looking good Rgds, Hans "It's okay to make mistakes. mistakes are our teachers - they help us to to learn, even if it is painfully" Current Build: Endeavour Cross section,D51 Completed: HMS Victory Under the bench: Endeavour x 2,Sovereign of the Seas, Akagi and The Black Pearl!HMS Victory Cross Section
Hi Hans thank you for your kind words  Regards Mike MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
ISSUES 28 AND 29 Hi Team before I continue with Issue 30 I wanted to make sure the Hull and Deck were married together properly. The first thing I did was cover the inside of the Hull with PVA adhesive, as I am building a static model epoxy adhesive is not needed here is a photo:- MWG attached the following image(s): MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
ISSUE 28 and 29 Next job was to fit the three stern decks, I said before I was going to screw down the Decks, I prepared the decks for this:- MWG attached the following image(s): MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
ISSUE 28 and 29 The decks had been sanded to the ribs and when I screwed them in place they had alighned perfectly  :- MWG attached the following image(s): MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
ISSUES 28 And 29 And the final part was to fit the Central Deck area Isanded the sides untill it fitted between the planking:- I will fit the Stern embelishments next. Comments and Questions welcome  Regards Mike MWG attached the following image(s): MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
Joined: 11/05/2011 Posts: 766 Points: 2,128 Location: Dagenham
Looking great mate. If u was doing the rc version wouldn't the PVA inside the hull be enough? CURRENT BUILDS
Mclaren MP4-23 Ford 1/12 Shelby Mustang GT500 2010 HMS Pandora
Hi Sean, If you were doing the R/C version you would need to use the Epoxy adhesive because it would need to be waterproof, PVA would not be enough  I hope that answers your question ok  and thank you for your nice comments  Regards Mike MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
ISSUE 29 In this issue we received part 129 Bulwark piece and 20x second planking pieces:-  Regards Mike MWG attached the following image(s): MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
ISSUES 29 AND 30 I should have mentioned issue 29 is the start of the second planking. In Issue 30 we received,the second Bulwork piece no 130 the two pieces (129 and 130 )will be fitted to the stern. We also received 20x planks for the second planking  Regards Mike MWG attached the following image(s): MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
ISSUE 31 This week we recieved 40x planks for the second planking. Before next week I will fit the two bulwarks and start the second planking  Questions and comments welcome  Regards Mike MWG attached the following image(s): MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
MWG wrote:ISSUE 16 DECKING BEAMS I then sanded the frames very well, as per the instructions, but I also sanded the deck beams flush with rib tops which they are attached too. I spent alot of time on this area in order to fit the Deck flush, and the frames to come in and out freely. I feel this is one of the most important parts to get right, so please do not rush this stage Hi, I'm new here so hello and I find your build very helpfull. The question I have is if my model is going to be static can I glue the deck down rather than have it removable at this part of the build, or do you need to be able to remove it in the future ? Thanks in advance
Hi Spitfire, As you progress with the build you will fit parts 116 and 117 to the sides of the stern, at this point make sure you have lined the inner hull with PVA (this will give the ship strength, and prevent the planks from moving) You could stick down decks 104, 105 and 112 as I have done (you do not need to screw them down,I have done this for my own piece of mind) because these (116 and 117 )parts require glueing to the sides of deck 104 and 105. I have not glued the other deck pieces yet, just incase the future instructions require us to access the inner hull. I am about to fix parts 116 and 117. I hope my answer helps you.  Regards Mike MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
comming together nicely mike. keep up the good work ian. Current builds.Hachettes build the bismark,HMS Victory, HMS Hood. Finished Builds Corel HMS Victory cross section.
Thanks Ian for your kind words  Regards Mike MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
Joined: 16/07/2011 Posts: 165 Points: 457 Location: South Wales
Hi Mike, When you screw down the decks on your model what are you screwing into? Did you make and glue wooden blocks or screw into the frames. Reason I ask is I have just received my issues 28-31 and am building a static model so want to fix these deck down but not sure whether to do as you have done or just glue them down. Cheers. Gareth Completed models,Hachette Titanic.Deags. Hms Victory. Hachette Hems Hood.Ongoing builds. Deags Akagi,Deags Sovereign of the Seas,Deags Spitfire,On my wish list.Yamato.Royal Navy world war 2 aircraft carrier.
Hi Gaz I am screwing into the frames, plus I am using Adhesive I can plank over the countersunk screws, I hope that answers your question  Regards mike MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
Guest (10)
