What's gone wrong - damper unit crank problem Options
hil26
#1 Posted : 13 April 2012 14:50:41
Rank: Amateur level 2
Putting the damper unit stages 3 and 4 together, middle section of crank is not in correct position when connected to rear supension unit. It is almost upright!
Have taken it apart a number of times, gone through each stage of putting together again looking at Tomicks images - all seems same, then when I screw to gearbox and connect suspension up goes the middle crank.
Any ideas on where I might be going wrong?
Help greatly appreciated - hopefully the images show the problem
Note - obviously not in the correct postion in the images, but even when it is, it's the same
Dave
Skiddy
#2 Posted : 13 April 2012 15:13:50
You may have them handed wrong ie swop them over
hil26
#3 Posted : 13 April 2012 15:54:04
Believe it or not, just after I posted this, went back and went through all again, and yes it was the middle carnk giving the problem!!!
Feel very much a simpleton at the moment
cheers
Dave
#4 Posted : 13 April 2012 15:58:52
You've assembled the units incorrectly.
If you look at yours, the 'outer' smaller cranks are curving outwards, away from the car centre line.
They should be curving inwards, the same as the larger cranks.
You need to disassemble them, and fit ALL of the cranks 'curving' in the same direction.
You can see this clearly in pictures 4 and 5 on page 13 of issue 44.
All the best, Roy.
#5 Posted : 13 April 2012 16:18:46
I did pick up this problem several weeks ago, when I said that the spue that hold said parts should have been numbered,this is the first kit I have made that was not numbered,and thanks to tomicks close ups I was able to sort it right,and got hammered for being a beginner to f1 and didn't know how an f1 car worked.as it happened I was building f1 cars before that kid was born.so just crack on and keep trying,like me to get it right.
hil26
#6 Posted : 13 April 2012 16:21:10
Thanks folks - all sorted now Blushing Blushing
numbering the sprues would have been helpful
Dave
This page was generated in 0.101 seconds.
