Joined: 23/04/2011 Posts: 45 Points: 138 Location: Portsmouth
 Rank: Super-Elite        Groups: Official Builds, Administrators, Moderator, Global Forum Support, Registered Joined: 04/06/2011 Posts: 5,188 Points: 15,713 Location: ipswich
If this problem is going to start costing DeAg much in the way of money, I hope they don't just 'Pull the plug' on it. Partworks have been known to suddenly stop all too often.
As an aside: ADMIN - if you are reading - please can you change the music on your customer services line. I've listened to 'The Blue Danube' a dozen times in the past few days before getting cut off. At least give us a bit of variety whilst we are waiting to hear the inevitable recorded voice telling us the call is going to be terminated. Roy.
The series will run its full course
Joined: 05/12/2011 Posts: 57 Points: 141 Location: Cannock
Joined: 20/12/2011 Posts: 134 Points: 384 Location: barnoldswick
come on deag answer the phone and responability and replace my parts please
Joined: 05/04/2011 Posts: 266 Points: 784 Location: Essexshire
This topic has started to go off in different directions and doesn't really help us, but I do appreciate peoples concerns...believe me.
It would be easier for Deag to come back with an answer to one topic than several of the same.
I can only see one solution to this, for Deag to send those that have built these parts up to AUTOMATICALLY be sent replacements for the front and rear. Not sure how many in the UK have started building this model but looking at the 10,000 plus that have viewed the first of Tomick's build there will be some that have not even started but...if there are 10,000 of us trying to make a call to Deag then the lines will be clogged. There is also the possibility of some that just want the spares so my suggestion is...we send Deag photo proof of built parts and they send the replacements. I cannot walk into a shop and say replace this thankyou so much, so this may be a route to go that is genuine.
I too think that the laquer should be supplied as part of the kit.
I look forward to a reply from either Deag ( admin ) or Tomick.
BTW...if these parts can be supplied and confirmed as such then I will be able to resume my build.
I totally agree with your comments, EXCEPT for the part about photo-proof of build. I'm the first to admit I haven't started my build yet, but it doesn't alter the fact this is DeAg's problem, NOT mine. If I can get the spare parts, I'm entitled to them the same as anyone else, if only to 'experiment' my alternatives. As I've already mentioned elsewhere, to get a GOOD fix 'might' mean re-painting all the red parts myself. As to requests being 'genuine', surely anyone who has bought the parts so far is 'genuine' - built up or not. I don't see why I should risk my original parts on a DIY fix that has been dumped on me by DeAg. Roy.
roymattblack wrote:I totally agree with your comments, EXCEPT for the part about photo-proof of build. I'm the first to admit I haven't started my build yet, but it doesn't alter the fact this is DeAg's problem, NOT mine. If I can get the spare parts, I'm entitled to them the same as anyone else, if only to 'experiment' my alternatives. As I've already mentioned elsewhere, to get a GOOD fix 'might' mean re-painting all the red parts myself. As to requests being 'genuine', surely anyone who has bought the parts so far is 'genuine' - built up or not. I don't see why I should risk my original parts on a DIY fix that has been dumped on me by DeAg. Roy.  Fair do's mate you have a point
Joined: 01/07/2011 Posts: 383 Points: 1,194 Location: Birmingham
I finally got through. Took 4 attempts of being cut off. Advised of the problem and they are sending me replacements 2-4 weeks dependant of availability. Once i've received these i'll prob break up the original and have a trial run on them with a couple of different laquers to see which works best! I still think front and rear wing should be replaced with pre-laquered parts. But hey, I'll give it a go.
Ian is that front and rear ?
Have tried a brush on laquer and just makes it shiney with no colour change....still different.
Ian is that front and rear ? Have tried a brush on laquer on a spare piece of wing and just makes it shiney with no colour change....still different.
Well, i've told them the rear wing has the same issue as well, so fingers crossed they replace front and rear but only time will tell. But again, they had no idea there was a known issue
Got through a few minutes ago and the assistant seemed to know all about it. Front wing parts on the way at no cost. Hopefully when they get to grips with the rear wing issues, it will be treated the same. I have to say customer service was very helpful and friendly, so definitely no complaints there. In fact, the real moans ought to be directed at Kyosho, the makers of the kit. Roy.
Joined: 04/05/2011 Posts: 173 Points: 528 Location: Sussex
Im gutted about all this because I have already placed Johnnie walker logos on my rear wing and I don't have any more. None of the reds on any of these parts totally match the Mclaren Red but I do remember thinking when I started the build why are the wing components not glossy. I am concerned with calling customer services and requesting new parts that I then suddenly get charged for them because of their reply of "I don't understand".
roymattblack wrote:Got through a few minutes ago and the assistant seemed to know all about it. Front wing parts on the way at no cost. Hopefully when they get to grips with the rear wing issues, it will be treated the same. I have to say customer service was very helpful and friendly, so definitely no complaints there. In fact, the real moans ought to be directed at Kyosho, the makers of the kit. Roy. Isn't acceptance of replacement from a company deemed as case closed ? ( front only )
Joined: 24/07/2011 Posts: 54 Points: 142 Location: dewsbury west yorkshire
thanx for sheding a tiny light on the subject and we are finally getting somewhere however it is both front and rear wing parts so the people who have subscribed to this build should have the correct parts resent automaticaly and those who use the newsagent should get there newsagent to reorder for them FoC (free of charge) and they should all be pre lacquered as my 8 year old son is not allowed to use aerosols nor am i any good at spraying and in the advertisments for this build it said all parts come prepainted plus why has this not happened to the jappanise build if it did then why was this problem not addressed before it started in this country
Joined: 11/05/2011 Posts: 766 Points: 2,128 Location: Dagenham
So r we getting replacement parts then or do we have to call de ag??? CURRENT BUILDS
Mclaren MP4-23 Ford 1/12 Shelby Mustang GT500 2010 HMS Pandora
If you want replacements then you have to make the call
Thanks tom CURRENT BUILDS
hey tomick i have made the call and customer service said they didnt now anything about it is it possible to make sure that all parts reguarding this issue are the correct parts and no charge is made
