 Rank: Pro  Groups: Registered
Joined: 07/01/2011 Posts: 399 Points: 1,212 Location: Penhill Estate, Western Cape, ZA
Thanks Ian! No problem Erthro, that will be great. After fitting the fighting top, it was time to finish the top section of the lower main mast: I tried cutting the little 2x2x2mm pieces, but that didn't work, so I decided to fit the little "spacers" longer and then trim them off after they have set.   The Main mast with the rubbing pauch fitted and 2 coats of paint:
Once again a good looking job there Stephan. Rgds, Hans "It's okay to make mistakes. mistakes are our teachers - they help us to to learn, even if it is painfully" Current Build: Endeavour Cross section,D51 Completed: HMS Victory Under the bench: Endeavour x 2,Sovereign of the Seas, Akagi and The Black Pearl!HMS Victory Cross Section
Thanks bud, Shaping the upper main mast and top gallant  Top of the lower mast with the mast cap fitted  The main topmast and cross trees  I glued the hand-rail as instructed, but it came apart when I test-fitted it - will have to think of another solution.
Ok, so I had to make the join for the hand rail stronger. Drilled 2mm holes, 2mm deep, in the 4x4 and pared the ends of the 3mm dowel down to 2mm. Presto:   The octagonal support on the topgallant - this takes a little longer to get right than one might suspect.
Looks fiddly and finiky but you seem to have nailed it ( excuse the pun) Rgds, Hans "It's okay to make mistakes. mistakes are our teachers - they help us to to learn, even if it is painfully" Current Build: Endeavour Cross section,D51 Completed: HMS Victory Under the bench: Endeavour x 2,Sovereign of the Seas, Akagi and The Black Pearl!HMS Victory Cross Section
Nice work Stefan!! Keep the pictures coming... Current Builds: Deagostini HMS Victory: Deagostini HMS Sovereign of the seas. Completed Builds: Del Prado: HMAS Bounty: Hachette: RMS Titanic: Del Prado: Cutty Sark...
Thanks Hans & Jonny I decided to deviate from the mast pain scheme depicted in the Magazine and paint as per the pictures in the book - it may not be historically accurate, but I like the contrast of the yellow and black. Hand rail painted and fitted: (Apologies for the overexposure)  Top mast painted  Top gallant fitted and painted. (The top ball has now also been painted black)  Cross trees and mast cap fitted  I managed to loose one of the heart shaped blocks so I ended up having to make one from scratch (Left hand side in the picture)  Main mast fitted to the ship.
Looking good Stefan. You know Sod's law says, you lose one, you make one and then you find one, after all your effort and trouble. Rgds, Hans "It's okay to make mistakes. mistakes are our teachers - they help us to to learn, even if it is painfully" Current Build: Endeavour Cross section,D51 Completed: HMS Victory Under the bench: Endeavour x 2,Sovereign of the Seas, Akagi and The Black Pearl!HMS Victory Cross Section
Lots of work this weekend, not so many pictures. Main yard being shaped:  Main yard built and dressed  Construction of the fore mast fighting top in progress
Hi Stefan nice clean crisp build  Regards Mike MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
Well done Stefan...Looking real good as usual mate... Current Builds: Deagostini HMS Victory: Deagostini HMS Sovereign of the seas. Completed Builds: Del Prado: HMAS Bounty: Hachette: RMS Titanic: Del Prado: Cutty Sark...
Joined: 20/10/2010 Posts: 511 Points: 1,459 Location: Loughborough
Looking really good there stefan your build isreally coming on now, and i love the yellow accents on the mast, i might have to pinch that one  . Keep up the good work. Builds in progress: HMS Victory.HMS Surprise. Completed builds: Revell London Bus 1/24. Builds to do:Sovereign of the seas, Hms Albion.
Joined: 29/03/2010 Posts: 190 Points: 512 Location: Lytham UK
Hi Stefan.. Your Victory build is looking great. Best regards, Ian Ian Builds in progress: E-type, HMS Victory, HMS Endeavour, HMS Soverein of the Seas Wish list: Bentley Blower http://forum.model-space...spx?g=posts&m=30439
http://mxpublishing.co.uk/engine/shop/product/9781780920184/Hunt+for+the+Blower+Bentley
Thank you very much for your kind comments gentlemen. The fore-mast fighting top is now complete. I've also completed the shaping of the fore-mast  The ring is much easier to paint while fitted to the mast.   Once again I found the fitting of the rear rail on the fighting top tough going. Even though all the holes tie up 100% the supplied wire is very soft and ensuring that the wires are fitted perfectly perpendicular to either the base or the top of the rail is very difficult. Combine this with superglue and the odds of a curse or 2 escaping increases exponentially. I've got an idea to change the construction process - will try it out on the mizzen mast fighting top when I get there and then share with you.
Hi Stefan...I had the same trouble with the rail on both main and fore tops mate..very fiddly, especially when using super glue!! She is looking great though mate!!...
StefanDV wrote:I've got an idea to change the construction process - will try it out on the mizzen mast fighting top when I get there and then share with you.
Yae to that. It really is a pleasure watching other peoples builds and picking up tips as we go. It's certainly inspiring. Well done Stefan. John
Thanks lads! Some more work on the fore mast over the weekend: The threads being tied.  The lower part of the fore main mast painted and the fighting top glued on.
Looks great. I had similer trouble with rail but I decided to use just one pece of timber not to to form the rail which helped. J “Whenever you find yourself on the side of the majority, it is time to pause and reflect.” -Mark Twain
Just sanded back the first coat and applied another coat of paint to the foremast last night, so I won't bore you with those pictures. Also constructed the fore mast cross-trees. The method described in the magazine to keep the cross-trees straight and perpendicular (lining them up on a cutting mat) may work for some, I still wasn't 100% happy with it, so I did the following: 1. Cut little pieces of 5mm wide planking (to space the braces) 2. Used the braces to evenly space 3 lines on 2 longer pieces of hull planking spares. 3. Placed the planks back to back and drilled 3 x 0.75mm holes in the middle of the lines marked in 2 4. Pinned the curved pieces of the cross-trees in the holes marked above 5. Glued the braces to the curved parts and then used the spacers cut in 1 to ensure the braces were spaced 5mm apart. 6. Squared up the assembly and leave it to dry overnight
Good clean work done there, Stefan, well done, keep it up. Rgds, Hans "It's okay to make mistakes. mistakes are our teachers - they help us to to learn, even if it is painfully" Current Build: Endeavour Cross section,D51 Completed: HMS Victory Under the bench: Endeavour x 2,Sovereign of the Seas, Akagi and The Black Pearl!HMS Victory Cross Section
Guest (14)
