56 Pages «<2728293031>»
#561 Posted : 27 March 2012 12:37:04
ISSUE 28 AND 29
At this point I revisited the Bow and trimmed the edges of the deck back to the ribs.
I was then able to fit properley the bow side panels we received in ISSUE 28
I will be using screws wit adehsive to fix the decks down.
questions and comments welcomeBigGrin Regards Mike
#562 Posted : 27 March 2012 14:26:48
Looking good mike.
like your extra deck support idea ian. BigGrin
#563 Posted : 28 March 2012 02:13:25
Thank you for your nice commentBigGrin Regards Mike
Hans
#564 Posted : 28 March 2012 11:03:16
Looks like some great building going there Mike. Looking good
Rgds, Hans
Endeavour Cross section,D51
Completed: HMS Victory
#565 Posted : 28 March 2012 13:04:58
Hi Hans thank you for your kind wordsBigGrin Regards Mike
#566 Posted : 01 April 2012 20:54:44
ISSUES 28 AND 29
Hi Team before I continue with Issue 30 I wanted to make sure the Hull and Deck were married together properly.
The first thing I did was cover the inside of the Hull with PVA adhesive, as I am building a static model epoxy adhesive is not needed here is a photo:-
#567 Posted : 01 April 2012 22:47:15
ISSUE 28 and 29
Next job was to fit the three stern decks, I said before I was going to screw down the Decks, I prepared the decks for this:-
#568 Posted : 01 April 2012 22:50:22
ISSUE 28 and 29
The decks had been sanded to the ribs and when I screwed them in place they had alighned perfectlyBigGrin :-
#569 Posted : 01 April 2012 22:55:51
ISSUES 28 And 29
And the final part was to fit the Central Deck area Isanded the sides untill it fitted between the planking:-
I will fit the Stern embelishments next.
Comments and Questions welcomeBigGrin Regards Mike
S2ksean
#570 Posted : 01 April 2012 23:09:09
Looking great mate. If u was doing the rc version wouldn't the PVA inside the hull be enough?
CURRENT BUILDS
Mclaren MP4-23
HMS Pandora
#571 Posted : 02 April 2012 00:57:52
Hi Sean,
If you were doing the R/C version you would need to use the Epoxy adhesive because it would need to be waterproof, PVA would not be enoughBigGrin I hope that answers your question okBigGrin and thank you for your nice commentsBigGrin Regards Mike
#572 Posted : 07 April 2012 14:45:13
ISSUE 29
In this issue we received part 129 Bulwark piece and 20x second planking pieces:-BigGrin Regards Mike
#573 Posted : 07 April 2012 14:53:22
ISSUES 29 AND 30
I should have mentioned issue 29 is the start of the second planking.
In Issue 30 we received,the second Bulwork piece no 130 the two pieces (129 and 130 )will be fitted to the stern.
We also received 20x planks for the second plankingBigGrin Regards Mike
#574 Posted : 07 April 2012 14:59:21
ISSUE 31
This week we recieved 40x planks for the second planking.
Before next week I will fit the two bulwarks and start the second plankingBigGrin Questions and comments welcomeBigGrin Regards Mike
spitfirebbmf
#575 Posted : 09 April 2012 20:24:10
Rank: Newbie
MWG wrote:
ISSUE 16 DECKING BEAMS
I then sanded the frames very well, as per the instructions, but I also sanded the deck beams flush with rib tops which they are attached too.
I spent alot of time on this area in order to fit the Deck flush, and the frames to come in and out freely.
I feel this is one of the most important parts to get right, so please do not rush this stageBigGrin
Hi,
I'm new here so hello and I find your build very helpfull.
The question I have is if my model is going to be static can I glue the deck down rather than have it removable at this part of the build, or do you need to be able to remove it in the future ?
Thanks in advance
#576 Posted : 10 April 2012 09:45:36
Hi Spitfire,
As you progress with the build you will fit parts 116 and 117 to the sides of the stern, at this point make sure you have lined the inner hull with PVA (this will give the ship strength, and prevent the planks from moving)
You could stick down decks 104, 105 and 112 as I have done (you do not need to screw them down,I have done this for my own piece of mind) because these (116 and 117 )parts require glueing to the sides of deck 104 and 105.
I have not glued the other deck pieces yet, just incase the future instructions require us to access the inner hull.
I am about to fix parts 116 and 117.
I hope my answer helps you.BigGrin Regards Mike
#577 Posted : 13 April 2012 15:16:39
comming together nicely mike. keep up the good work ian. BigGrin
#578 Posted : 14 April 2012 10:34:10
Thanks Ian for your kind wordsBigGrin Regards Mike
Gaz
#579 Posted : 14 April 2012 15:44:40
Hi Mike, When you screw down the decks on your model what are you screwing into? Did you make and glue wooden blocks or screw into the frames. Reason I ask is I have just received my issues 28-31 and am building a static model so want to fix these deck down but not sure whether to do as you have done or just glue them down.
Cheers.
Gareth
Completed models,Hachette Titanic.Deags. Hms Victory. Hachette Hems Hood.Ongoing builds. Deags Akagi,Deags Sovereign of the Seas,Deags Spitfire,On my wish list.Yamato.Royal Navy world war 2 aircraft carrier.
#580 Posted : 14 April 2012 20:23:28
Hi Gaz I am screwing into the frames, plus I am using Adhesive I can plank over the countersunk screws, I hope that answers your questionBigGrin Regards mike
Guest (12)
This page was generated in 0.333 seconds.
