Modellers drill Options
Cotterel1964
#1 Posted : 21 March 2012 09:44:23
Hi, is anyone using a mini drill to start the screws off on the mclaren build?
If so what size drill bit would you recommend?
only1ianuk
#2 Posted : 21 March 2012 20:44:57
I'm just using the usual tip on the forum to put a bit of vaseline on the end of the screw and it works a treat.
Skiddy
#3 Posted : 21 March 2012 21:04:42
Just using a decent set of drivers and no problems even without the lube
David rozee
#4 Posted : 22 March 2012 19:09:46
Washing up liquid works as well on the threads
bigmal0
#5 Posted : 20 April 2012 21:03:10
Hi All
With regard to the various screws, I found a set of watchmakers taps on ebay, they are just right for threading the holes to allow the screws to fit easily, the taps cost £11 +pp and come on a plate with holes to test screw sizes.
