nice build ar,I would just fill,takes a few mins. Current builds: SotS, USS Consitution, San Felipe, D51 loco, HMS Surprise, RB7, Arab Dhow, Jotika HMS Victory Completed builds: HMS Pickel, Thermopylae, Mississipi river boat, Mary Rose, Cutty Sark, San Francisco II, HMS Victory x5, Titanic Lifeboat, Panart HMS Victory Launch, Hachette Titanic, Virginia Schooner, Endeavour Longboat. http://www.model-space.com/gb/
 Thanks for the reply's Karl,MWG iv contacted C/S about a replacment part,not sure about the filling as its an exposed part like the deck etching pieces,so its look is important on the finished model regards Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
 Hi All the hull is now fully profiled using the templates suplied [ even though 2 are missing from the download,luckily these are at the stern]now all that remains to be done is the final filling and sanding before i decide wether or not to epoxy the hull on the outside to get a more steel like finish.But before that happens i need to fit the stern section profiles around the rudders and add some enhancements around the propeler hull area i have in mind regards Andy arpurchase attached the following image(s): Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
She's taking shape nicely
 Thank you Mr T Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
 Hi All progress update iv recieved the replacment decking part now so on with the build.Added the rails in the hangar deck as Mr T has but also added the hanger doors as an addition.The wire that will be provided for the rails i will not be using as iv decided to use plastic strip to replicate this item on the build.More pics to follow shortly of this months build as usual all coments are welcome regards Andy arpurchase attached the following image(s): Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
looking great andy Come on you Jimmies
 Thank you Saintsman Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
You are doing a great job of your build Andy  Regards Mike MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
 Thanks for the encouragement Mike Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
 More pics on progress, i used the old hot iron trick to transfere the stencil image onto the underside of the deck.If your not familiar with doing this its quite easy, borrow the wifes iron,set it to highest heat [ get her to go shoping 1st  ] cut out the template line it up on the deck[correct side of course]then run the iron over the template the heat should then transfer the image.I had to do a little extra marking as the deck gratings cut out hinders /prevents transfer there,pics will make this apparent 'note' this method will work on 80% of plans so with the other 20% its the carbon copy paper transfer job.As usual all comments are welcome regards Andy arpurchase attached the following image(s): Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
What good idea Andy   regards Mike MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
 Glad to share Mike its a tip given to me from another builder years ago when i used to scratch build model aircraft from plans Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Joined: 13/01/2012 Posts: 605 Points: 1,630 Location: Bucks
very clever HMS Surprise HMS Snake HMS Bounty HMS Royal Caroline HMS Victory rebuild HMS Supply
 Thank you Moriarty Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
 Bow deck plate now added,small amount of sanding and filling needed on the hull but the fit was almost perfect,the paint looks shiny because it was still wet when the pic was took regards Andy arpurchase attached the following image(s): Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
love the silver socks Current builds: SotS, USS Consitution, San Felipe, D51 loco, HMS Surprise, RB7, Arab Dhow, Jotika HMS Victory Completed builds: HMS Pickel, Thermopylae, Mississipi river boat, Mary Rose, Cutty Sark, San Francisco II, HMS Victory x5, Titanic Lifeboat, Panart HMS Victory Launch, Hachette Titanic, Virginia Schooner, Endeavour Longboat. http://www.model-space.com/gb/
 Silver socks? Karl am i loseing the plot here Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
 A few more pics this time of the stern rudder fairings,i found the wood provided was of an extreamly hard grain/density but managed to compleat the rounding of the section as per instructions,Getting close to preparing the hull for painting now just need to add my deck edge enhancement to the edge of the planked area and if your wondering the decking will not be started untill all the hull is painted and assotiated bits added to the main hull.As ussual all comments are welcome regards Andy arpurchase attached the following image(s): Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
hi ar.the last pic of that deck.looks like you have crossed your legs and are wearing silver socks Current builds: SotS, USS Consitution, San Felipe, D51 loco, HMS Surprise, RB7, Arab Dhow, Jotika HMS Victory Completed builds: HMS Pickel, Thermopylae, Mississipi river boat, Mary Rose, Cutty Sark, San Francisco II, HMS Victory x5, Titanic Lifeboat, Panart HMS Victory Launch, Hachette Titanic, Virginia Schooner, Endeavour Longboat. http://www.model-space.com/gb/
