16 Pages <12345>»
Hans's Humble Victory Options
saintsman123
#41 Posted : 12 March 2012 21:57:42
great work hansBigGrin
Come on you Jimmies
StefanDV
#42 Posted : 14 March 2012 07:54:42
Well done Hans - she's looking spectacular! All the extra effort and detail you're putting in is really paying off.
#43 Posted : 14 March 2012 08:26:16
Great Job HansBigGrin Regards MikeBigGrin Cool
Hans
#44 Posted : 14 March 2012 09:47:22
Thanks Comic123, Saint, Stephan and Mike, appreciate your support.
Rgds, Hans
Endeavour Cross section,D51
Completed: HMS Victory
#45 Posted : 14 March 2012 21:57:13
Hans,
Hello, I have just looked at your post ! welcome to the miniature world,your furniture look's very much the part,it's pleasing to see your effort as I am well aware of what it takes to complete,it just shows the skill level you have.I think the day cabin with the lights look's as if you are about to sit for a meal, as for the red curtins and round table spot on Hans.Also to take in to consideration that you had to remove the Galley without damage and to go to all this that's dedication.
The upper deck, I think the cannons look the part, along with your colour of the deck all in all great effort,look forward to more pictures.
regards trev.
Hans
#46 Posted : 15 March 2012 09:51:09
Thanks Trev. Trust me when I say the skill still needs plenty of honing. I found that jewellers head gear with varying lenses helps a lot. Makes life a little easier not to mention seeing better.
Thanks for the compliments and encouragement.
Rgds, Hans
saintsman123
#47 Posted : 15 March 2012 13:01:10
hans this is a guy in the uk's work, i have seen him on t.v. a few times and as far as miniature work goes, i think he is the master. he uses things like the hair from a fly as paintbrushes......yes a fly...., and has to slow his heart rate down, and paint in time with his heartbeat to avoid the slightest movement. some of the sculptures are made from a single grain of rice.
http://www.willard-wigan.com/gallery.aspx
Come on you Jimmies
Hans
#48 Posted : 15 March 2012 13:24:34
Thanks Bob, very very impressive, the guy must have a extreme amount of patience, particularly with figures. I'm not sure I'll go that far. This was purely an exercise to be slightly different and take owership of the ship and make it personal. Although must admit liked the idea of being challenged, especially as this is my first build.
Rgds, Hans
#49 Posted : 15 March 2012 21:53:40
BigGrin Outstanding quality buildCool
moriarty
#50 Posted : 15 March 2012 21:58:48
that is some linkLove Love
HMS Surprise
HMS Snake
HMS Bounty
HMS Royal Caroline
HMS Victory rebuild
HMS Supply
Hans
#51 Posted : 16 March 2012 07:18:11
Thanks Ar, appreciated.
Rgds, Hans
#52 Posted : 16 March 2012 14:42:39
Fantastic build hans keep up the good work ian Cool
Hans
#53 Posted : 19 March 2012 08:02:44
Thanks very much for the kind words Ian.
Rgds, Hans
Silent_Running
#54 Posted : 19 March 2012 08:20:15
Hi Hans,
That's a really neat build you've got there, and its a credit to you. Can you tell me what you used to get such a glossy finish on the hull in post 30?
Glenn
Hans
#55 Posted : 19 March 2012 11:08:58
Hi Glenn, thanks for the encouragement.
I used a 25% reduced imbuia matt varnish on the deck and teak gloss varnish on the hull. It is the type used on outside wooden decking for our harsh sunny conditions. I only used three coats with a light sanding in-between coats, to avoid it showing up too yellow. I brushed it on and it closed up the brush marks quite well. Hope this helps.
Rgds, Hans
Hans
#56 Posted : 20 March 2012 07:14:47
Hi all, for those that might be interested,I discovered a 12 volt LED strip that come in 5 metres flexible self adhesive roll and you are then able to cut every 3 LED's. It has a positive and negative patch on either end, where you can solder the wires in series for corners, bends, extentions etc. I have used a fine comms cable, the one used for security gates and intercoms, that I strip for the lenghts I need. A laptop 12 volt battery charger reduces our 220v to 12vdc. Looks fantastic when lit. If it helps I can post the specs. I have not found that the LED's produce too much heat, it only provides 4.8 to 5w alum. The strips themselves appear to be a foil of sorts that defuses the heat as well. Trust this helps your cause.
Rgds, Hans
pierre50
#57 Posted : 07 July 2012 20:30:40
Hi Hans
Like your detail & lighting, stunnig mate BigGrin
Pierre
Current Buid:
HMS Victory
Next Build:
Wish List:
Santa Ana
Bounty
Santisima-Trinidad
#58 Posted : 07 July 2012 21:40:46
Stunning work!
Hans
#59 Posted : 09 July 2012 07:57:32
Thanks for your support Pierre and Dadokta. A little behind with the updates. Busy with the masts at the moment. plenty of work and hours and you wonder if you will ever finish.
Rgds, Hans
Sietsemk
#60 Posted : 10 July 2012 12:58:38
I like the idée with the LED’s, your build is looking good HansThumpUp
Built
Albatross, build in 1982 from plans.
Hms Bounty, build in 1987 from plans.
Duyfken,build in 1991 from plans
Oosterland, build in 1998 from plans
In the meantime.
HMS Victory (Deagostini)
2011 Building MFV63 fishing trawler from plans.
HMS Mayflower (Kit)
Wish list
Still planning.
16 Pages <12345>»
