 Rank: Pro  Groups: Registered
Joined: 07/01/2011 Posts: 399 Points: 1,212 Location: Penhill Estate, Western Cape, ZA
Well done Karl. Thanks for all your great hints and tips!
Joined: 15/09/2010 Posts: 175 Points: 517 Location: Durban RSA
She is coming on very nicely.
I like your method of fabricating the centre pin rails.
Happy building
Athol
  the centre pin rails and rear transom decoration fitted. Current builds: SotS, USS Consitution, San Felipe, D51 loco, HMS Surprise, RB7, Arab Dhow, Jotika HMS Victory Completed builds: HMS Pickel, Thermopylae, Mississipi river boat, Mary Rose, Cutty Sark, San Francisco II, HMS Victory x5, Titanic Lifeboat, Panart HMS Victory Launch, Hachette Titanic, Virginia Schooner, Endeavour Longboat. http://www.model-space.com/gb/
here I'm attempting to emulate the knightheads(that thingy that holds up the anchor) http://www.pbase.com/mic...lszewski/image/57403554
 I've done this in the sandwich method,I used scaps of 6mmx1mm.the pics will explain all.if anyone wants the dimensions of the bits used just shout.sorry not up to s.o.bs graphic artistry.         that's it for now,got to add the wedgy things to the knightheads and a bit more paint. Current builds: SotS, USS Consitution, San Felipe, D51 loco, HMS Surprise, RB7, Arab Dhow, Jotika HMS Victory Completed builds: HMS Pickel, Thermopylae, Mississipi river boat, Mary Rose, Cutty Sark, San Francisco II, HMS Victory x5, Titanic Lifeboat, Panart HMS Victory Launch, Hachette Titanic, Virginia Schooner, Endeavour Longboat. http://www.model-space.com/gb/
good idea karl Come on you Jimmies
I've started on the shrouds only to experiment with whippings,and the general overall look.comments very welcome,good or bad,I won't mind changing or redoing it if it is not right.     I will be dropping back to filling up the cannonball racks and rigging the guns on the deck. Current builds: SotS, USS Consitution, San Felipe, D51 loco, HMS Surprise, RB7, Arab Dhow, Jotika HMS Victory Completed builds: HMS Pickel, Thermopylae, Mississipi river boat, Mary Rose, Cutty Sark, San Francisco II, HMS Victory x5, Titanic Lifeboat, Panart HMS Victory Launch, Hachette Titanic, Virginia Schooner, Endeavour Longboat. http://www.model-space.com/gb/
hi karl did you use the fly fishing method of preparing the deadeye/shroud lashings? as the lashings look a little big for the rest of the shroud, i only say this as you are looking for some feedback. perhaps prepare the lashings on a smaller drill bit/dowel/nail or whatever you use. i went off track when i did mine, as the magazine pictures of lashings on the actual victory looked different to the way described in the step by step. i tied the shrouds to the deadeyes in 3 places 1. on the top of the deadeyes 2. around 10mm up from the deadeyes 3. around 3mm up from the deadeye the picture i used for reference was on page 13 of issue 92 the black and white drawing it also meant that i had physically tied the shroud to the deadeye so i knew it wouldn't slip also i know the front cover pictures are not quite what we are building but it looks as though thats was the way done there. hope you don't mind me telling you this karl, especially with your modelling experience, which i glean from all your diaries keep up the good work Come on you Jimmies
Hi karl!
I see you haven't fitted the hammock cranes and netting yet, you will find it hard to fit them with the shrouds lashed in place mate.
Also I'm sorry to tell you that the ekeing rail on your port side is fitted to the upper beakhead rail while your starboard ekeing rail is fitted to the lower beakhead rail.
Darron
thanks for the feedback gentlemen,saint first,having another look at the lashings and see if I can reduce the diameter.sob I did have an idea of fitting the hammock cranes already made up,gonna put me thinking cap on.and will correct the bow end. Current builds: SotS, USS Consitution, San Felipe, D51 loco, HMS Surprise, RB7, Arab Dhow, Jotika HMS Victory Completed builds: HMS Pickel, Thermopylae, Mississipi river boat, Mary Rose, Cutty Sark, San Francisco II, HMS Victory x5, Titanic Lifeboat, Panart HMS Victory Launch, Hachette Titanic, Virginia Schooner, Endeavour Longboat. http://www.model-space.com/gb/
   right,first I've corrected the bow stringers(sob)then removed the lanyards so I could fix the crane nets.and finally lashed the bowsprit. Current builds: SotS, USS Consitution, San Felipe, D51 loco, HMS Surprise, RB7, Arab Dhow, Jotika HMS Victory Completed builds: HMS Pickel, Thermopylae, Mississipi river boat, Mary Rose, Cutty Sark, San Francisco II, HMS Victory x5, Titanic Lifeboat, Panart HMS Victory Launch, Hachette Titanic, Virginia Schooner, Endeavour Longboat. http://www.model-space.com/gb/
Well done Karl - your build is coming along splendidly!
nice work karl. i think it's a bit easier to put the shrouds and other rigging on before the gunport lids, as i kept getting the lashing thread wrapped around them and pulled a couple off in the process. Come on you Jimmies
 looking good Karl Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
thanks for the comments gents,yes saint agree the gunport covers should have been later. Current builds: SotS, USS Consitution, San Felipe, D51 loco, HMS Surprise, RB7, Arab Dhow, Jotika HMS Victory Completed builds: HMS Pickel, Thermopylae, Mississipi river boat, Mary Rose, Cutty Sark, San Francisco II, HMS Victory x5, Titanic Lifeboat, Panart HMS Victory Launch, Hachette Titanic, Virginia Schooner, Endeavour Longboat. http://www.model-space.com/gb/
Cracking good job there Karl..Its a great build mate!!... Current Builds: Deagostini HMS Victory: Deagostini HMS Sovereign of the seas. Completed Builds: Del Prado: HMAS Bounty: Hachette: RMS Titanic: Del Prado: Cutty Sark...
 this is where I'm at,at the moment,fore and main mast shrouds done,mizzen just started,I had a roll of softish wire 1mm. so I cut a piece of 5mm.x2mm. x 20mm.plank and used that to make up the deadeye spacers so that I couls adjust as I went along. Current builds: SotS, USS Consitution, San Felipe, D51 loco, HMS Surprise, RB7, Arab Dhow, Jotika HMS Victory Completed builds: HMS Pickel, Thermopylae, Mississipi river boat, Mary Rose, Cutty Sark, San Francisco II, HMS Victory x5, Titanic Lifeboat, Panart HMS Victory Launch, Hachette Titanic, Virginia Schooner, Endeavour Longboat. http://www.model-space.com/gb/
Cracking along at a good pace! Dont know how you have the time to do so many kits at once? I struggle with the two I have at the moment. Steve..
hi steve,a very understanding wife,thinks she wants me out of the way,as long as i cook,washup,and hoover she is good as gold. Current builds: SotS, USS Consitution, San Felipe, D51 loco, HMS Surprise, RB7, Arab Dhow, Jotika HMS Victory Completed builds: HMS Pickel, Thermopylae, Mississipi river boat, Mary Rose, Cutty Sark, San Francisco II, HMS Victory x5, Titanic Lifeboat, Panart HMS Victory Launch, Hachette Titanic, Virginia Schooner, Endeavour Longboat. http://www.model-space.com/gb/
 all the hammocks done the forestays,wiggles,and the first stay sail. Current builds: SotS, USS Consitution, San Felipe, D51 loco, HMS Surprise, RB7, Arab Dhow, Jotika HMS Victory Completed builds: HMS Pickel, Thermopylae, Mississipi river boat, Mary Rose, Cutty Sark, San Francisco II, HMS Victory x5, Titanic Lifeboat, Panart HMS Victory Launch, Hachette Titanic, Virginia Schooner, Endeavour Longboat. http://www.model-space.com/gb/
Guest (5)
