56 Pages «<2627282930>»
#541 Posted : 08 March 2012 16:55:16
Hi mike.
Realy good tips on tapering planks.
as the bootom of keel is planked. there is a lot of planks that need to be tapered towards the bow and stern, areas. as was on my Bismarck. IanCool
#542 Posted : 08 March 2012 23:23:56
Thanks for that IanBigGrin you are right about the bottem of the hull, I spoke to HachetteBigGrin Regards MikeBigGrin
#543 Posted : 19 March 2012 00:01:34
ISSUES 24,25,26, and 27
Hi Team I have now finished the work on these issues, to my satisfaction. The Hull is sanded and prepared for the second planking.
The first photos are of the Bow, you will see I used 5mm x 2mm planks around the tight curve, this has given a better shape and good fixing for the second planking, I checked with Hachette and the second planking is 5mm x 2mm.:-
#544 Posted : 19 March 2012 00:08:35
The next photos are of the stern, after planking I poured neat PVA adnesive in the Hull covering the inside of the planks, I will still use plasterers tape and epoxy adhesive before I fix the planks down:-
#545 Posted : 19 March 2012 00:15:59
ISSUES 24,25,26 and 27
The final photos are of the centre of the Hull, I have used 5mm x 2mm planks where the sides of the Hull meet the base, this has again given in my opinion a better shape.
Questions and comments are welcomeBigGrin Regards Mike
S2ksean
#546 Posted : 19 March 2012 11:31:25
Someones been a busy boy. Looks great mike. I did the same thing inside the hull with the glue. It's made it alot stronger plus water tight if I later decide ta RC it
CURRENT BUILDS
Mclaren MP4-23
HMS Pandora
#547 Posted : 19 March 2012 16:12:35
Thanks for the nice comment SeanBigGrin your build is coming along great as wellBigGrin Regards Mike
#548 Posted : 19 March 2012 20:18:36
ISSUE 28
This is what we received this week (All to do with the Bow)BigGrin Regards Mike
#549 Posted : 20 March 2012 00:55:34
hull looks perfect mate Cool
#550 Posted : 20 March 2012 02:43:23
Thanks for the encouragement JaseBigGrin much appreciated, Regards mike
#551 Posted : 20 March 2012 14:19:56
ISSUE 28
Hi Team, Just to give the heads up, fret 2993 contains parts 125 and 126, while fret 2994 contains parts 128 and 127. they look the same, but have different hole configuration. I cut out the parts and numbered them,and sanded the pieces:-
#552 Posted : 20 March 2012 14:23:14
ISSUE 28
Next up was to fit parts 125 and parts 127 with the off cuts of planking:-
Virtue86
#553 Posted : 20 March 2012 14:27:54
Your hull looks excellent Mike, your tips are really useful to me as well as there are many things i haven't done before. Progression like that is going to get you any excellent final product. Hope mine is even half as good.BigGrin
Cheers
Peter
[b]Built:1:250 Titanic
#554 Posted : 20 March 2012 14:29:19
ISSUE 28
Now we can fit these parts to the Bow, following the instructions.
All that we have left to do now is trim back the Decking flush with the ribs in order to fit parts 126 and 128.
Thats all for nowBigGrin questions and comments welcomeBigGrin Regards Mike
#555 Posted : 25 March 2012 20:17:18
ISSUE 29
This is what we received:-
A part for the stern.
and planks for the second planking 5mm x 1mm
#556 Posted : 25 March 2012 23:26:39
BigGrin coming together nicely MikeCool
#557 Posted : 26 March 2012 11:21:57
Cheers Andy BigGrin I think it will make a great static modelBigGrin Regards Mike
#558 Posted : 26 March 2012 13:43:10
ISSUE 29
Before fitting the parts this week I thought it was worth taking some time looking how the decks will fit with these Bow and Stern parts we are receiving.
The first thing I did was sand to fit the two stern deck pieces, I then fitted extra supports for these deck pieces, here are the photos:-
I used 4 cut pieces of 5mm x 2mm planking, I am making a static model so these modifications will not interfer with any thing infact it will give a better fixing at the join of Deck pieces 104 and 105
#559 Posted : 27 March 2012 12:13:09
ISSUE 29
Hi Team the next thing I did was to level up the third deck from the stern, I found it was 2mm too low so I cut some pieces of 5mm x 2mm planking and fitted these (Did anyone else have this problem?) I then sanded the sides of the deck level with the ribs here are the photos:-
#560 Posted : 27 March 2012 12:21:07
ISSUE 29
Here is a view from the side, I can now fit the extra plank.
Then there is a photo of the sanded deck.
It pays to take some time over this build it is not always as straight forward as it appears the Deck alignment is very important
This page was generated in 0.348 seconds.
