thickness of glass case Options
Skiddy
#1 Posted : 07 March 2012 16:59:42
As above, those that have already bought their display cases would someone please let me know what the thickness of their glass is ie either 3 or 4mm. I'm about to start making mine.
Thanks a bunch in advance BigGrin
driving4life
#2 Posted : 07 March 2012 17:22:13
Rank: Amateur Level 1
are u using acrylic or glass?
noki49
#3 Posted : 08 March 2012 00:10:41
I was thinking of making my own out of glass.
If I can find a glass shop that is willing to cut the glass accurately, it's just a case of sorting a suitable glue and a nice wooden plinth.
I'm sure I can make one with plenty of change from the £85 for the one on ebay.
Skiddy
#4 Posted : 09 March 2012 21:46:28
Glass mate
Skiddy
#5 Posted : 09 March 2012 21:57:10
Square is easy, will get all the edges polished as well.
It's prob going to cost easy £50 - 60 and will be using 12mm and 6mm mdf.
I am going to sandwich 10 led's in the top and 10 in the base. I have bought 13mm and 20mm ali square u shape tube for the base and the top. The mdf will be covered in some very nice carbon effect sheet and the back glass will be black window film with the Mclaren logo within.
I have all the bits apart from the mdf and glass, so once I get the board this weekend i will make a start.
Don't like the one's on ebay especially the lead cover ups on the joints.
noki49
#6 Posted : 11 March 2012 22:49:18
Let us know how this progresses.
How will you join the glass, will you glue it ?
I was looking at some aluminium angle in B&Q to cover the edges.
Skiddy
#7 Posted : 12 March 2012 16:23:58
Going to clear silicone ( high modulus ) as per my tropical tank. Less obtrusive than angle or lead. Only going to use ali on the base and top.
Skiddy
#8 Posted : 16 March 2012 21:43:07
You got me thinking about acrylic instead of glass. My se7en car I built has a 5mm acrylic shorty screen and I thought.....why not !
So have now ( thanks to you ) ordered some 4mm acrylic already cut £ 30
only need 4 sides as the top and bottom are solid.
Have nearly made the top and bottom, will be finished end weekend. In the end I have used 20mm ext 17mm int ali channel encapsulaing 3 layers, 6mm and 6mm MDF and 3mm harboard spacer which all locks into the u channel. The led's are sandwiched within.
Pic is channel holding layers together while setting
Skiddy
#9 Posted : 16 March 2012 21:47:07
leds 006.JPG (2,832kb) downloaded 102 time(s).
Senna94
#10 Posted : 16 March 2012 22:00:17
I don't know how I missed this thread before but that looks brilliant!
I was thinking of maybe designing a display case as if the car was 'in the garage' at McLaren, but this has got me thinking as it looks brilliant!
May come begging for advice when I get round to making the case mate!
Keep us updated!
Building the McLaren MP4-23
driving4life
#11 Posted : 16 March 2012 22:05:43
the 4mm acrylic cut, how did u attach them ? did you have them smoothed finished because from wht i have been told the plastic when bonding with the solvent shatters it. im interested in knowing how u did it without that happening? out of interest what are the internal dimenions of ur display case? . for the base i was thinking of using contiboard or pvc that ppl use for window boards and using edging strips to finish it off, id use internal pvc strips which id drill holes for my leds and use rgb strips and controller which u can get cheaply operated by remote.
Skiddy
#12 Posted : 16 March 2012 22:54:01
Going to use acryic bonding cement....it's all on youtube 'how to'
Haven't got the acrylic yet hopefully get delivered early next week.
Size overall will be 700mm x 300mm x 300mm.... acrylic size will be approx 20mm less in all measurements....thereabouts, did't want it looking squashed so kept the height up. Will post pics of it finished probably end next week.
Skiddy
#13 Posted : 18 March 2012 22:24:07
MCLAREN MARCH 12 001.JPG (2,718kb) downloaded 135 time(s).
Senna94
#14 Posted : 19 March 2012 14:29:20
Looking good!
Skiddy
#15 Posted : 20 March 2012 15:44:53
Sorry noki missed this one. The angle is from B&Q £10 just over for 2 metres
This page was generated in 0.153 seconds.
