Joined: 20/04/2010 Posts: 545 Points: 1,536 Location: lossiemouth
planking came out better than i thought it would
Joined: 11/05/2011 Posts: 766 Points: 2,128 Location: Dagenham
Looking good will, I was wondering how long it would be before you put up a dairy for hood CURRENT BUILDS
Mclaren MP4-23 Ford 1/12 Shelby Mustang GT500 2010 HMS Pandora
Hi Willie, your planking is firstclass  Regards Mike MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
 Good job on the planking m8 Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
this is the alterations i did for the 4 shaft drive the servo is a slim aeron to miss the inboard shafts
Joined: 06/08/2011 Posts: 480 Points: 1,421 Location: Galway
Beginning to look like a ship, keep up the good craftsmanship  , Ger
Joined: 25/01/2012 Posts: 134 Points: 385 Location: Berwick Upon Tweed
Looking really good Willie. I am just preparing my bulkhead edges to take the planking. Will update the build diary soon. A quick question though, do you think we have to sand the deck edge back to the bulkhead as it looks like this is the images through the instructions. I only ask because at the minute the deck edge projects a reasonable amount and it seems wrong to take it that far back. Cheers Peter
Current builds: Amati 1:200 Hood; D51 200 Bought and on the waiting list: HMS Endeavour's Longboat, 1:90 San Juan Nepomuceno, Titanic Lifeboat,1:200 Bismarck Strip and Rebuild [b]Built:1:250 Titanic
Hi Virtue, do not take the deck back at this stage, having spoken to Hachette there is more to come  Regards Mike MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
HY VIRTUE watch out for frame 11 the double one to make a nice fit for the planks where the bump is remember check with a plank when sanding thats all i can say the rest stright forward p.s i wish i taken a frac tion more at this point when i rub my finger accros this point i feel a bump more to the bottom it will clear by sanding
more planking
 comming together nicley Willie Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Nice job Willie  Regards Mike MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
though you might like a look at this one 46 glow engine driving a 50 mm prop at 10,000 rpm
front planking up to date
Cheers for the heads up on frame 11 willie, i haven't had much time recently due to work to get on with it so i still working my way through preping the hull frames. i will make sure that i have sanded it back enough. Your model is looking really good, smooth planking to the bow  , hope i get it to that level of finish. well done Cheers Peter
VIRTUE86 you can take your time keep checking your planks not once but a few times even though you dont sand
this weeks aft planking
really good work willie, very clean and neat. Come on you Jimmies
fitting of the inboard prop shafts this is not part of the build but my extra
