56 Pages «<2526272829>»
#521 Posted : 03 March 2012 21:53:49
ISSUE 24, 25, and 26
This is the last photo for this tutorial, more to come tomorrow on another subject.
I am dissapointed this Partwork does not come with trenails or pins please buy a couple of packets before you start building.
ISSUE 24 comes with approx 40 planks but it tells you the issue contains 20 planks the extra are required later in the build, please store them away safelyBigGrin
I hope this has been useful to you, I will have completed the 3 issues by tomorrow,and I have found some strange things with this build which I will highlite to youBigGrin
Questions and comments welcomeBigGrin Regards MikeBigGrin
#522 Posted : 04 March 2012 10:22:50
BigGrin Great tutorial Mike as you say its easy for us old lags doing this but for the newbies theres lots of pitfalls to avoid
#523 Posted : 05 March 2012 15:07:40
Hi Mike.
Some realy great tips. keep up the good work Ian.Cool
#524 Posted : 05 March 2012 22:04:59
Thanks Andy for your commentsBigGrin Regards MikeBigGrin Cool
#525 Posted : 06 March 2012 09:36:13
Hi Ian, thanks for that mateBigGrin Regards MikeBigGrin Cool
#526 Posted : 06 March 2012 09:39:32
ISSUES 24,25 and 26
TAPER AND BEVEL PLANKS
Hi Team I have compiled a series of photos to best explain this process:-
This first process is a bevel (sanding the edge of the plank so it butts up to the next plank)
First sand at an angle, then run some glue down the edge, then fix with pins up to the next plank (using EVO STIK weatherproof adhesive
--- Blue bottle )
Then wipe off excess adhesiveBigGrin Questions and comments welcomeBigGrin
S2ksean
#527 Posted : 06 March 2012 16:24:12
Looking good mike. I never glued the edges of the planks which I suppose thinking about it I should of but will it make that much of a difference cause if so il glue the inside
CURRENT BUILDS
Mclaren MP4-23
HMS Pandora
Virtue86
#528 Posted : 06 March 2012 17:01:35
I have been using this technique over the last couple of days while planking, im just working through issue 23 a the minute and i will be following your build log for tips.
Its a big help seeing how you do it. I will be uploading photos in the coming days so you can see what you think of my progress.
Cheers again Mike
V86
Cheers
Peter
[b]Built:1:250 Titanic
#529 Posted : 06 March 2012 19:15:52
Hi Sean, no worriesBigGrin In this case coat the inside with epoxy adhesive.
If you are making your build R/C, one of Mr T`s tips I picked up sometime ago is to use Plasterers webbing one side is self adhesive, with the epxy adhesive.BigGrin
In all my builds I bevel the plank and use adhesive between each plankBigGrin Regards MikeBigGrin
#530 Posted : 06 March 2012 19:28:57
ISSUES 24, 25, and 26
Hi Team I have found a potential problem, at the Stearn rib 39 and 40,I did not have firm rib to fix my planks too here are some photos to highlite the problem and how I overcame it:-
I identified the gap, fitted a 75mm length of 5mm x 2mm.
Then I shaped the piece and finaly fitted the plank.BigGrin (both sides have the same problem.
Questions and comments welcome Regards MikeBigGrin Cool
S2ksean
#531 Posted : 06 March 2012 20:50:39
I had the same problem a few weeks back mike. This is what I did
(ignore the glue it will come off) I used one piece and tapered both edges the cut it in half fitting it in the gap at an angle so the rib was flat. Just another idea although ours is properly the better of the two.
Sean
CURRENT BUILDS
Mclaren MP4-23
HMS Pandora
#532 Posted : 06 March 2012 21:29:01
Hi Sean, I am really pleased you identified the problemBigGrinyour remedy to fix it was first classBigGrin if it works for you dont knock itBigGrin well done mate, regards MikeBigGrin ThumpUp
willie
#533 Posted: : 07 March 2012 09:54:08
hy MWG your planking coming on greatBigGrin by the way i check there no dried glue in the corners where the plank tuches the frame if there is i remove it even the smallest amount, to make the next plank even a closer fit
saintsman123
#534 Posted : 07 March 2012 11:08:38
it seems a bit daft that the kit makers would leave such a big gap, it somtimes makes you wonder if anyone in the company actually makes their own kits.
also i sometimes worry that somewhere way, way, down the line that there may be a reason for some of these gaps/other problems, and that in issue 100 for example, there is some instruction mentions why you should not have filled the gap or whatever. i suppose that is always going to be a partwork problem as you are always "flying blind".
keep up the good work mike
Come on you Jimmies
#535 Posted : 07 March 2012 11:57:19
Thanks for your nice comments WillieBigGrin Regards MikeBigGrin
#536 Posted : 07 March 2012 11:59:00
Thanks Bob for your positive commentsBigGrin Your points are very validBigGrin Regards MikeBigGrin
#537 Posted : 07 March 2012 13:52:52
ISSUES 24 25 and 26
TAPERING THE PLANKS
Hi Team as promised a series of photos showing a method of tapering;-
In the two examples you can see what I have done to shape the planks to fit the space, you will also see I have also used 5mm x 2mm planks instead of the ones supplied, this has allowed me to get a better curve where requiredBigGrin
#538 Posted : 07 March 2012 14:05:29
willie
#539 Posted : 07 March 2012 16:34:48
Confused may be fore draining the back end if you have a leak Confused
#540 Posted : 07 March 2012 18:22:09
TAPERING THE PLANKS
Hi again here are some more photos:-
The last photo shows the small gaps that appeared, before fitting the planks I pinned this on just to show you,I then took it off tapered the ends of the plank, bevelled the edge and glued itBigGrin
This page was generated in 0.339 seconds.
