surprise decking Options
moriarty
#1 Posted : 02 March 2012 00:26:30
just got the decking sealed up and the walls painted. Well chuffed at how that danish oil performs.BigGrin
HMS Surprise
HMS Snake
HMS Bounty
HMS Royal Caroline
HMS Victory rebuild
HMS Supply
astronut01
#2 Posted : 02 March 2012 11:36:37
Rank: Amateur Level 1
It's looking good Moriaty. I've just finished the upper planking and due to start the inner walls, though haven't had the instuctions for that work yet. Is it done using the same planks as that on the outside?
I've also used Danish oil on my deck.
Astro
saintsman123
#3 Posted : 02 March 2012 11:57:28
you're flying along there moriarty, looking good
Come on you Jimmies
moriarty
#4 Posted : 02 March 2012 12:22:26
Hi guys , I was in a bit of a dilema on which wood to use. In the end I just used the lime planking for the walls as the decking material is too nice for walls although it has the strengh to take fittings for when the guns are installed.I planked the whole wall because of the lights that I am fitting and also at a later stage all the relevant walls for the cabins. This was done at a price however and I have had to order some more lime strip to complete to the waterline.Crying
HMS Surprise
HMS Snake
HMS Bounty
HMS Royal Caroline
HMS Victory rebuild
HMS Supply
moriarty
#5 Posted : 02 March 2012 17:11:35
Just thought I,d point out that I have used the wrong wood on the deck ,but I think it looks better. I will use the proper stuff below the bottom whales and every where else. Also looking through the inventory of parts I cannot see any galley or pumps, is this so or do we get them or is this something to make ourself?
HMS Surprise
HMS Snake
HMS Bounty
HMS Royal Caroline
HMS Victory rebuild
HMS Supply
Ger C
#6 Posted : 03 March 2012 13:12:01
Lovely decking,
But a quick question, is it best to varnish as you go along or do the whole model when its finished?
Thanks
Ger
moriarty
#7 Posted : 03 March 2012 13:42:40
hi ger, I think the varnishing aspect is always down to personal preference. I have usually built say a complete hull and then decorated, but I presume to have a fairly steady hand when it comes to that. There is always the quality of the build as well, Paint will hide and varnish will show.Confused
HMS Surprise
HMS Snake
HMS Bounty
HMS Royal Caroline
HMS Victory rebuild
HMS Supply
This page was generated in 0.158 seconds.
