10 Pages «<56789>»
Sean's HMS hood Options
willie
#121 Posted : 08 February 2012 18:56:02
maybe you sould have waited to see the rest of the planking before removing it could have been ok by the look of it,then remove if wrong
#122 Posted : 14 February 2012 09:38:42
Hi Sean,
If you need any planks I have some 5mm x 2mm which can be addapted to fit, if you look at my build I have used some already under the hull at centre and sternBigGrin Regards MikeBigGrin
S2ksean
#123 Posted : 14 February 2012 21:07:35
Cheers mike I appreciate that mate. Im off work from Thursday to Monday so il be hopefully doing some more work on it then.
CURRENT BUILDS
Mclaren MP4-23
HMS Pandora
#124 Posted : 14 February 2012 21:10:56
You are welcomeBigGrin look forward to seeing your buildBigGrin Regards MikeCool
S2ksean
#125 Posted : 16 February 2012 17:59:47
Issue 23
Finally managed to finish this one. I didn't realise how long planking takes but I'm getting there
I've got issue 24 I've not started it yet. I was thinking about using sawdust in PVA glue to fill in the little gaps in the planking once this layer is done so hopefully it will be nice an smooth once it's done.
CURRENT BUILDS
Mclaren MP4-23
HMS Pandora
#126 Posted : 16 February 2012 18:38:00
Hi Sean if it is anything like the Bizzy it will have some element of double planking, I will phone Hachette tomorrow and ask.
Your work looks greatBigGrin dont do anything serious untill I find out.
My ISSUE 24 did not arrive yetBlink Regards MikeBigGrin Cool
S2ksean
#127 Posted : 16 February 2012 18:48:07
Thx mike. I'm not able to pin the planks into position cause I don't have any so I'm using clamps. Its taking a bit longer but has the same effect I think lol. Sorry ta hear about ur latest issue it's got 41planks (I think) and also contains the missing parts from a previous issue tho u already made ya own. It's wierd cause although it's giving ya all these planks it's only giving the instructions for 20 of them. Hope this helps
CURRENT BUILDS
Mclaren MP4-23
HMS Pandora
#128 Posted : 16 February 2012 19:21:12
BigGrin Hi Sean the extra planks will be used in future ISSUESBigGrin put them safe.
You could nip into a Hobbycraft and get some train track pinsBigGrin Regards MikeBigGrin
willie
#129 Posted : 16 February 2012 19:55:09
hi sean how about trieing this with elestic bands put around oppisit frame under the plank your fitting up and back to the same frame crossing the frame it pulls the plank in and up agenest the other plank at the same time the pice off 3x3 is to kept the joints flush as possible to each other not nedded all the time p.s. if you do use this idear the top plank only needs to be clamped or held some way to stop it ridding up the frame till the glue dries
S2ksean
#130 Posted : 16 February 2012 23:42:23
Cheers mike. Thats a good idea willie il give it a go cheers.
CURRENT BUILDS
Mclaren MP4-23
HMS Pandora
S2ksean
#131 Posted : 20 February 2012 11:12:26
Mike did u find out if the hull is double planked?
CURRENT BUILDS
Mclaren MP4-23
HMS Pandora
S2ksean
#132 Posted : 27 February 2012 16:30:23
Issue 24
CURRENT BUILDS
Mclaren MP4-23
HMS Pandora
willie
#133 Posted : 27 February 2012 18:24:28
looking good SEAN have you try the rubber bands for holding the planks
S2ksean
#134 Posted : 27 February 2012 18:27:45
Cheers willie and yeah I tried it and it's came in handy for a few of the planks so thank u for the advice
CURRENT BUILDS
Mclaren MP4-23
HMS Pandora
willie
#135 Posted : 27 February 2012 18:38:42
when doing the last plank with the bands put it right around the hull and pack the bands with off cuts so you pull only on the plank you are fixing watch you dont glue the off cuts as well
S2ksean
#136 Posted : 27 February 2012 18:46:28
Issue 25 (part 1)
Only managed to do half of 25 today but I'm now waiting for glue to dry on the last couple of planks then il hopefully start the over side in the next few days.
Comments welcome
CURRENT BUILDS
Mclaren MP4-23
HMS Pandora
S2ksean
#137 Posted : 27 February 2012 18:47:54
Cheers willie il try that aswell
CURRENT BUILDS
Mclaren MP4-23
HMS Pandora
#138 Posted : 27 February 2012 20:41:40
Good stuff SeanBigGrin Regards MikeBigGrin Cool
S2ksean
#139 Posted : 27 February 2012 20:43:40
Cheers mike appreciate it. Bin meaning ta ask ya mike how's the tiger build going?
CURRENT BUILDS
Mclaren MP4-23
HMS Pandora
#140 Posted : 27 February 2012 20:52:28
Hi Sean I am fed up waiting for the one piece turret barrel, I think I will build it as is Huh Glare Regards MikeBigGrin
10 Pages «<56789>»
