14 Pages <1234>»
sandnesspeats Options
#21 Posted : 27 February 2012 11:51:41
[quote=saintsman123]I think you should check with mrT , as I think it looks ok. There should be a groove for bow sticky out bit to fit in.
look at the official build diary.
http://forum.model-space....uk/resource.ashx?a=877[/quote]
Dontshootme is correct in saying that the stern frames need to be level with the keel which lies between them, it appears there is a slight groove.
#22 Posted : 27 February 2012 12:36:30
yes john the rib does almost disappear,so soldier on m8.
sandnesspeats
#23 Posted : 27 February 2012 14:10:38
right ok!! will get it to just about level.
Thank you all Again.BigGrin
Cool Cool
saintsman123
#24 Posted : 27 February 2012 15:19:30
apologies for the confusion, as i said i didn't see the stern picture...........good luck with the rest of your build
Come on you Jimmies
StefanDV
#25 Posted : 27 February 2012 15:43:53
Hi Rob,
If I were in your position, I would remove the 3 row of planking that you have done at the bow and refit them, but with much more tapering towards the bow, i.e. have the planks taper from 5mm to 2.5mm from about frame 12 towards the box. After that, follow the instructions in the magazine and have a look at the different build dairies. I got about halfway down the hull before realising that I have not faired the ribs around the bow enough :(
sandnesspeats
#26 Posted : 27 February 2012 23:11:56
Hi StefanDV,
strange you should say that,it crossed my mind to take them off and redo them,as they just did not look right,not enough taper on them did look iffy.I seen some of the builds and they were rising up and not straight if you know what I mean and I was going for straightBlushing Blushing Blushing.
I just wanted to get it done I suppose(big mistake)I will do that at the weekend.I think now it is time for patienceCool Cool.
cheers mateyBigGrin BigGrin
hey saint,no probs thanks for the help.
sandnesspeats
#27 Posted : 18 March 2012 23:56:09
Hi Guys,latest pics of my build, does it look ok so far as I have filled the frames with balsa wood which has helped to get the line right.
Bow and stern has three (one to go)bow looks the same,the two stern planks have not been glued yet just needed some advice if they look ok or not.I have been a very long time trying the bend,Crying Crying still does not look right but will it be ok??Huh
sandnesspeats attached the following image(s):
z8000783
#28 Posted : 18 March 2012 23:57:41
Groups: Unapproved
... and the pics?
John
#29 Posted : 19 March 2012 00:37:30
Hi Rob, I completed 11 rows of planking before I needed to taper planks looks like you are in the same situationBigGrin so now when you fit a plank let it follow the path it wants to, then you taper it to fit that track. If you have triangular spaces (you should get these)then fit a piece of timber cut to fit that space (called stealers)please continue to soak the plank, fit it without adhesive with pins, let it dry overnight,then you will find the shape will be fixed.then fit it with adhesive.BigGrin also put a bevel on the plank as it says in the instructions so it fits tight upto the next plankBigGrin
Your stern planks look fineBigGrin Regards Mike
StefanDV
#30 Posted : 19 March 2012 07:54:08
The planking's looking fine Rob. Well done - you're making great progress. Re the bending of the planks - what Mike (MWG) said.
Hans
#31 Posted : 19 March 2012 08:18:50
Nice clean lines. You are doing fine. Take your time and enjoy.
Rgds, Hans
Endeavour Cross section,D51
Completed: HMS Victory
sandnesspeats
#32 Posted : 19 March 2012 11:18:46
BigGrin BigGrin BigGrin
Thank you all for your tips and confidence boost,it does help I can assure you. I have a kitchen (food)steamer and a electric plank bender which I use for the planks,seems to work ok with the bending of the planks.
Thanks Again.Cool Cool Cool
saintsman123
#33 Posted : 19 March 2012 15:11:26
coming along nicely. you will be amazed at the result once you get it all done and sanded.
Come on you Jimmies
#34 Posted : 19 March 2012 22:04:08
BigGrin looking good there m8BigGrin
sandnesspeats
#35 Posted : 19 March 2012 22:06:27
Looks better now than the first pictures I sent.
thanks to all. great advice.
sandnesspeats
#36 Posted : 24 May 2012 22:55:27
hi All,
I am on issue 37 at the mo and i think everything is going ok!BigGrin BigGrin
Please look at the photos and tell me if this looks ok so far,thanks.
Do I need to take out all the pins yet.
Confused
StefanDV
#37 Posted : 25 May 2012 09:19:25
Nice Hedgehog LOL!
You can take the pins out as soon as the glue has set. I started every planing session by removing the pins from the previous session. (The little side-cutters in the free toolkit works very well for this)
sandnesspeats
#38 Posted : 25 May 2012 09:41:20
LOL LOLBigGrin .
should have taken them out after it dried,DOH!!!!
thanks stefanDV
Hans
#39 Posted : 25 May 2012 12:23:26
Good looking build there. Keep it up and the pics coming.
Rgds, Hans
#40 Posted : 25 May 2012 14:59:06
Hi you have a really nice build, if it was me I would be inclined to pull the pins out once the glue is setBigGrin Regards Mike
14 Pages <1234>»
