3 Pages 123>
willie's hood Options
willie
#1 Posted : 17 February 2012 17:33:56
planking came out better than i thought it would
S2ksean
#2 Posted : 17 February 2012 23:40:50
Looking good will, I was wondering how long it would be before you put up a dairy for hood
CURRENT BUILDS
Mclaren MP4-23
HMS Pandora
#3 Posted : 17 February 2012 23:43:40
Hi Willie, your planking is firstclassBigGrin Regards MikeBigGrin
#4 Posted : 18 February 2012 13:46:53
BigGrin Good job on the planking m8 Cool
willie
#5 Posted : 20 February 2012 17:19:49
this is the alterations i did for the 4 shaft drive the servo is a slim aeron to miss the inboard shafts
Ger C
#6 Posted : 22 February 2012 01:37:43
Beginning to look like a ship,
keep up the good craftsmanshipDrool ,
Ger
Virtue86
#7 Posted : 22 February 2012 13:09:23
Looking really good Willie. I am just preparing my bulkhead edges to take the planking. Will update the build diary soon.
A quick question though, do you think we have to sand the deck edge back to the bulkhead as it looks like this is the images through the instructions. I only ask because at the minute the deck edge projects a reasonable amount and it seems wrong to take it that far back.Confused
Cheers
Peter
[b]Built:1:250 Titanic
#8 Posted : 22 February 2012 14:18:43
Hi Virtue, do not take the deck back at this stage, having spoken to Hachette there is more to comeBigGrin Regards MikeBigGrin
willie
#9 Posted : 22 February 2012 17:09:11
HY VIRTUE watch out for frame 11 the double one to make a nice fit for the planks where the bump is remember check with a plank when sanding thats all i can say the rest stright forward p.s i wish i taken a frac tion more at this point when i rub my finger accros this point i feel a bump more to the bottom it will clear by sanding
willie
#10 Posted : 26 February 2012 10:54:08
more planking
#11 Posted : 26 February 2012 10:56:28
BigGrin comming together nicley WillieCool
#12 Posted : 26 February 2012 15:25:34
Nice job WillieBigGrin Regards MikeBigGrin
willie
#13 Posted : 26 February 2012 18:09:38
though you might like a look at this one 46 glow engine driving a 50 mm prop at 10,000 rpm
Ger C
#14 Posted : 27 February 2012 01:06:24
Lovely work,
Ger
willie
#15 Posted : 28 February 2012 13:13:38
front planking up to date
Virtue86
#16 Posted : 28 February 2012 19:11:04
Cheers for the heads up on frame 11 willie, i haven't had much time recently due to work to get on with it so i still working my way through preping the hull frames. i will make sure that i have sanded it back enough.
Your model is looking really good, smooth planking to the bow Cool , hope i get it to that level of finish. well done
Cheers
Peter
willie
#17 Posted : 28 February 2012 19:32:44
VIRTUE86 you can take your time keep checking your planks not once but a few times even though you dont sand BigGrin
willie
#18 Posted : 01 March 2012 16:58:12
this weeks aft planking
saintsman123
#19 Posted : 01 March 2012 18:29:49
really good work willie, very clean and neat.
Come on you Jimmies
willie
#20 Posted : 05 March 2012 19:36:01
fitting of the inboard prop shafts this is not part of the build but my extra
3 Pages 123>
