undoing a big mistake Options
stan21
#1 Posted : 17 February 2012 16:09:28
can anyone help im in a bit of a mess i spilt super glue on my front wing and bubbled the paint i got an extra one donated to me unasembled but i have glued the nose cone and every thing on except the top wing plane and i need to seperate the nose and other parts to be able to redo but i used a two part apoxy and it has set like steel (OOOPS)
so i would be eternally grate full for any ideasCrying
#2 Posted : 17 February 2012 16:16:39
You could try soaking in warm (not red hot) water which might make the expoxy soften.
Sadly if its a two part epoxy there isn't a release agent to help you on your way, you'll more than likley to break the parts before the bond.
#3 Posted : 17 February 2012 16:16:40
I think the best thing here is to start again,re-order the parts you need from the back order store.
now when using any glue apply with toothpicks or pins,never take the glue bottle to the object,I've ruined many a model doing that.
stan21
#4 Posted : 17 February 2012 16:56:58
thanx all i did use a tooth pick to apply and when my son droped the box early on in the build it came apart easy then but had only been a few weeks since i had done this i may have to pass it to him again lol
so ill just persivier with it i now use super glue and pipe weld just incase
