Issue 88 parts, or description incorrect? Options
Iain001
#1 Posted : 15 February 2012 23:51:18
Rank: Beginner Level 3
Hi,
I have just recieved my next delivery, but the parts supplied with issue 88 don't tie up with the description in this issue.
The description tells me I should have (apart from all the other items) 1.5m brown thread at 0.5mm thickness, 4m brown thread at 0.8mm thickness and 2 7mm deadeyes. I have 1.5m brown thread at 0.8mm thickness, a reel (presumably 4m) brown thread at 0.5mm thickness and 2 heart blocks instead of the deadeyes.
Can anyone tell me if the description in the issue incorrect or have I recieved the incorrect parts please?
Thanks
#2 Posted : 16 February 2012 09:24:56
Message was deleted by User.
#3 Posted : 16 February 2012 09:30:32
Descriptions are incorrect, certainly two heart blocks are contained and parts received should be as per the mag diagram
#4 Posted : 16 February 2012 09:50:51
I have the same as you comparing with the pic on the back of issue 87 there is hart blocks so assume correct.
Iain001
#5 Posted : 16 February 2012 11:22:00
Ah, thats great thanks. I had a feeling that my parts were probably correct but wanted to check with you guys first before contacting C/S as they would have only sent out another issue which would have been pointless.
BigGrin
This page was generated in 0.103 seconds.
