56 Pages «<2324252627>»
willie
#481 Posted : 06 February 2012 21:53:38
useing elestic bands in stead of pins, pulls the plank in and up at the same time the pins at the top of the planks were only used to stop the top plank sliding up at the begining
#482 Posted : 06 February 2012 21:58:15
Good tip WillieBigGrin Regards MikeBigGrin
#483 Posted : 13 February 2012 00:28:55
ISSUE 23
Hi everyone, I have completed ISSUE 23 and I would like to address people who have subscibed to this partwork, but as yet have not commenced building.
I have found when building this Great ship, there are things we need to do. When fitting the planks in this issue, we should shamfer the edge of each plank as it butts up to the next plank, this gives a better fit.
when fitting the planks, which go around the hull and underneath the hull,we should taper the planks in order to avoid a clinkering effect, also this stops any strain on the frame.
I believe these are points which could have been covered in more detail in the insructions.
I am including a range of photos, which I hope will help you in your build.
Questions and comments are welcomeBigGrin
This is what we received
#484 Posted : 13 February 2012 00:32:19
ISSUE 23
I fitted parts116 and 117:-
#485 Posted : 13 February 2012 00:36:03
ISSUE 23
#486 Posted : 13 February 2012 00:42:34
ISSUE 23
These are some of the tapered planks, and what I did with them:-
#487 Posted : 13 February 2012 00:48:46
ISSUE 23
Now some general photos of the finished build:-
#488 Posted : 13 February 2012 08:27:13
BigGrin coming together nicley now MikeThumpUp
Hans
#489 Posted : 13 February 2012 11:34:00
Great looking build there Mike.
Rgds, Hans
Endeavour Cross section,D51
Completed: HMS Victory
#490 Posted : 13 February 2012 12:40:13
Thanks Andy and Hans for your kind commentsBigGrin much appreciatedBigGrin Regards MikeBigGrin
#491 Posted : 13 February 2012 13:50:26
Looking good Mike Cool
#492 Posted : 13 February 2012 16:53:56
looking good mike, planking very neat Ian BigGrin
Virtue86
#493 Posted : 13 February 2012 17:28:17
Mike she is definitely looking like Hood now, can't wait to get my issues 20 - 23 in the post this week. Its looking really good and the planking is looking tidy. Hopefully i can keep mine that way, been a while since i planked a hull.
Keep it up
Cheers
Peter
[b]Built:1:250 Titanic
#494 Posted : 13 February 2012 21:07:48
Thanks for the encouragement TomBigGrin Regards MikeBigGrin
#495 Posted : 13 February 2012 21:08:54
Thanks Ian your comments are always welcomeBigGrin Regards MikeBigGrin
#496 Posted : 13 February 2012 21:12:16
Thanks Virtue, please make sure when you start to plank the Hull at ISSUE 22 that you put the first row of planks below the notch, not on the notch as it states in the instructionsBigGrin Regards MikeBigGrin Cool
#497 Posted : 14 February 2012 10:23:16
ISSUE 23
Hi Team as you are aware by now there are some instructions in this partwork which do not give clear build directions, and can be open to misinterpretationBlink and I am sure we will have more of this as the build progresses. Remember decks 104 and 105?
I will endeavour to highlite areas of concern every weekBigGrin ,so you who have not started the build yet, can steer around them.
One area I had to adjust is where the deck meets parts 116 and 117 I had to trim the tops of these parts, at the point at which the knife I am holding in the Photo meetsBigGrin you may not need to do this,but I am giving you the heads up,so you can watch out for itBigGrin
Question and comments welcomeBigGrin Regards MikeBigGrin
S2ksean
#498 Posted : 14 February 2012 21:11:38
Looks great mike cheers for the advice
CURRENT BUILDS
Mclaren MP4-23
HMS Pandora
#499 Posted : 14 February 2012 21:13:05
Hi sean I am glad to helpBigGrin Regards MikeBigGrin
#500 Posted : 14 February 2012 23:37:46
Looking good Cool
Guest (15)
This page was generated in 0.302 seconds.
