Joined: 13/01/2012 Posts: 605 Points: 1,630 Location: Bucks
it looks good and the trenailing sets it off, done to admiralty spec i presume  i have read that you can do it by rubbing a soft lead pencil(chippy one maybe) on just one side of the plank. i thought about a black permanent marker but will it bleed through and cause discolouration  . all the pro books say pencil but it is always better from the man on the job, learning by mistakes an all that. HMS Surprise HMS Snake HMS Bounty HMS Royal Caroline HMS Victory rebuild HMS Supply
Joined: 25/01/2010 Posts: 459 Points: 1,367 Location: Bridlington
Very nice work Rob  Regards Mike MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
do we get a prize for which one,s you use HMS Surprise HMS Snake HMS Bounty HMS Royal Caroline HMS Victory rebuild HMS Supply
those other guns look like some machined parts i saw a while ago, and i can't think what they were used for. they certainly do not look like guns at all. Come on you Jimmies
Joined: 15/04/2010 Posts: 1,266 Points: 3,841 Location: The Quantock Hills,Somerset
saintsman123 wrote:those other guns look like some machined parts i saw a while ago, and i can't think what they were used for. they certainly do not look like guns at all. They look almost like the pins used to hold on replacement wiper blades Rob Nolli Illigitimi Carborundum!!!Current Builds: HMS Victory, SV Thermopylae
moriarty wrote:do we get a prize for which one,s you use nope too easy Regards
Rob
Bridlington.
Built Flying Scotsman (Train). Collecting HMS VICTORY
Joined: 19/03/2010 Posts: 602 Points: 1,679 Location: Lincs
RE: Corking I use black electrical tape for the corking. I cut a length into 1mm strips and then superglue it to one side of each plank and then glue each plank together. Very tedious but the results look good also no bleed or smudging Dave You do not need a parachute to skydive. You only need a parachute to skydive twice.
Built: Golden Star, English Brig. RMS Titanic. (Academy 1/400 Centenary Anniversary Edition) Revell-Monogram 1/48 B-29 Superfortress 1:8 Baron von Richthofen's Fokker Tri-plane. HMS Victory. Nelsons Flag Ship. Sultan Arab Dhow. Artesania Latina Carmen II. The Battleship Yamato. Model Airways Wright Flyer 1:16 Scale. Trumpeter Bismarck 1/200. HMS Sovereign of the Seas. The Black Pearl.
 Well I've Picked up the craft knife again  , I'm Well behind  I should be doing it for a couple of hours Every day I hope I will post pic's as I go along, if there worth putting on Regards
Rob
Bridlington.
Joined: 09/02/2012 Posts: 569 Points: 1,675 Location: Scotland
No excuse now, look forward to watching your build progress.
MoMo
The correct cannon should be corronades, here is a photo:- I hope you dont mind me showing this? Kind regards Mike MWG attached the following image(s): MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
NO I don't mind at all looks great as well, n thanks to a kind friend Ive now got full 1:1 mast plans. Regards
Rob
Bridlington.
The wire snaps too easily. Regards
Rob
Bridlington.
I NEED better wire as the one supplied KEEPS snapping  Regards
Rob
Bridlington.
hi bob if you heat the wire it stops it snapping,I use a gas lighter. Current builds: SotS, USS Consitution, San Felipe, D51 loco, HMS Surprise, RB7, Arab Dhow, Jotika HMS Victory Completed builds: HMS Pickel, Thermopylae, Mississipi river boat, Mary Rose, Cutty Sark, San Francisco II, HMS Victory x5, Titanic Lifeboat, Panart HMS Victory Launch, Hachette Titanic, Virginia Schooner, Endeavour Longboat. http://www.model-space.com/gb/
Hi Karl, I'll give that ago thanks for the tip. Regards
Rob
Bridlington.
 Painting the inner lower deck walls Waiting for the post man to bring me some Hooks for ropes for the cannons.Regards
Rob
Bridlington.
Hi Robert,
I used the carrs solution, it was a while ago now, but I seem to do exactly what the instruction told me to do, but after 24 hrs in the solution there was hardly any colour change, so I left in the container and went on 2 weeks holiday, when I got back things were fine,
MoMo
