4 Pages <1234>
MWG buil diary of the Cutty Sark Options
#41 Posted : 29 January 2012 11:26:27
Thanks BudgieBigGrin you are very welcomeBigGrin Regards MikeCool
#42 Posted : 30 January 2012 15:34:19
hi Mike.
you mentioned mahogany planking, is it same thickness as normal planking.
wondering how it will bend being hard wood, and if it will pin without being drilled first. and if you will be painting it or danish oil to bring out its natural colour. Ian Cool
#43 Posted : 21 February 2012 23:41:13
Hi Ian sorry I missed your postBlink
The mag planking is 5mm x 2mm and yes it is not easy to bend consistantly.
I soaked the planks in hot water for at least 20 mins then fitted the planks to the hull wet with out adhesive using pins is not a problem, you need to drill the planks when you have tapered the planks so the pins do not split the wood.when the planks are dry I remove them, bevel the edges and taper where required, then fit again using adhesive.
I will use Danish oil when the Hull is sandedBigGrin
Thanks for your questionBigGrin
Regards MikeBigGrin Cool
saintsman123
#44 Posted : 21 February 2012 23:55:19
Mike there is something you can add to water to help soften the wood fibres to help them bend, i will look it up and let you know
Come on you Jimmies
saintsman123
#45 Posted : 22 February 2012 12:48:32
Aparantly if you add Ammonia to the water it helps soften the planks more, it is supposed to be good for hardwoods such as Walnut.
Now I suppose this might bring in some comments, as we all have a reliable source of ammonia, so I'm not suggesting we all pee on our wood BigGrinBigGrin
This info comes from Planking techniques for model builders, Underhill lent me a copy a few months ago one of his old relations gets qite a few mentions in it as he was a plan designer and model builder.
Come on you Jimmies
#46 Posted : 22 February 2012 14:24:09
Thanks Bob for the info on this formulaBlink I will give it a tryBigGrin but with real ammoniaBigGrin Regards Mike
#47 Posted : 25 February 2012 19:37:39
HULL WITH BALSA FILLETS
Hi Team the Balsa has now been sanded,faired and formedBigGrin all I have to do now is a little more medium sanding,the shape at the stern is great fof fitting the planks,see what you think:-
Questions and comments welcomeBigGrin Regards MikeBigGrin
#48 Posted : 09 March 2012 00:37:46
hi mike.
Very tidy filliting, looking forward to seeing your mahogany palanking Ian Cool
#49 Posted : 12 March 2012 14:21:03
Hi Mike,
love the balsa,good job.
Regards trev.
#50 Posted : 12 March 2012 19:02:32
Thanks Trev for your commentsBigGrin I have just finished all the fairing, I will post the Photos soonBigGrin Regards Mike
#51 Posted : 25 March 2012 20:02:46
BALSA FILLETS ON THE HULL
Hi Team as you know I have been fitting the whole Cutty Sark Hull with balsa wood here is the finished job:-
budgie
#52 Posted : 25 March 2012 20:07:04
BigGrin good stuff Mike bet she weighs a lot more now
Cool me thinks you will be glad to start planking now
#53 Posted : 25 March 2012 20:09:44
The last two photos show how easy it has been to get the shape of the Stern using this balsa method.
I am really pleased with the outcome, I have a great base to start my plankingBigGrin Questions and comments welcome.
Regards Mike
#54 Posted : 25 March 2012 20:12:08
Hi Budgie you are spot on, on both countsBigGrin Regards Mike
allanc62
#55 Posted : 25 March 2012 21:07:26
That's looking good Mike.
I might have to try the balsa method on my next model.
#56 Posted : 25 March 2012 21:28:24
Thank you allan for your nice commentBigGrin Regards Mike
#57 Posted : 25 March 2012 23:14:51
BigGrin Looking good Mike
Cool
#58 Posted : 26 March 2012 11:20:11
Thank you AndyBigGrin Regards Mike
#59 Posted : 13 April 2012 15:11:28
Looking good mike. look forward to seeing soome more pictures ian.Cool
jonny7england
#60 Posted : 13 April 2012 16:16:02
She is looking great Mike!!..Love ThumpUp
4 Pages <1234>
