Joined: 15/04/2010 Posts: 1,266 Points: 3,841 Location: The Quantock Hills,Somerset
Ian,I hate to add more to your work but the gun carriage is incorrect as well,the wide part should be the breach end. Rob Nolli Illigitimi Carborundum!!!Current Builds: HMS Victory, SV Thermopylae
Dontshootme wrote:Ian,I hate to add more to your work but the gun carriage is incorrect as well,the wide part should be the breach end. not according to issue 1. i'm sure when i went on victory they were all straight anyway, that is the same thickness front and back, and the ones on victory did not have cut out lines along the sides. which tells me that it makes no difference which way you put the thick end, just as long as you keep them all the same on you own model Come on you Jimmies
There was much discussion in the early days of the build,the gun carriage is wrong in the mag,there wouldnt have been deep cut lines down the sides,& should be wider at the breach. Rob Nolli Illigitimi Carborundum!!!Current Builds: HMS Victory, SV Thermopylae
hi guys issue 1 shows the plank the way the cannon was made. all the follow on issues with cannons show the plank the opposite way. i quess the superglue remover will be coming out. Thank you all for your comments Ian Current builds.Hachettes build the bismark,HMS Victory, HMS Hood. Finished Builds Corel HMS Victory cross section.
hi guys The Anchor has been corrected Thanks stefan. the Cannon is undergoing restoration. Thank you all for your coments Ian Current builds.Hachettes build the bismark,HMS Victory, HMS Hood. Finished Builds Corel HMS Victory cross section.
 Rank: Pro  Groups: Registered
Joined: 07/01/2011 Posts: 399 Points: 1,212 Location: Penhill Estate, Western Cape, ZA
It's always a pleasure to be able to help out a fellow shipmate! I sometimes wonder what the guys do who don't post build dairies
Joined: 15/09/2010 Posts: 175 Points: 517 Location: Durban RSA
Regarding rib 15 I found that the rib had to be lowered by filing the slot approx 1,5mm deeper. Check the deck support lugs are in line if they are, your solution is correct.
Happy building
Athol
hi Atholm Thanks for the information will check both options before fitting decking and fairing hull, Ian Current builds.Hachettes build the bismark,HMS Victory, HMS Hood. Finished Builds Corel HMS Victory cross section.
Hi all just a quick update on my build so far. Carronade completed with cut out slide groove. The launch has been built up to issue 10 iwill post some pictures of the laucnch when completed. The keel and ribs have been filleted and require a little more sanding down. ian smith attached the following image(s): Current builds.Hachettes build the bismark,HMS Victory, HMS Hood. Finished Builds Corel HMS Victory cross section.
Looking great Ian  Regards Mike MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
Thanks mike. Current builds.Hachettes build the bismark,HMS Victory, HMS Hood. Finished Builds Corel HMS Victory cross section.
Hi Guys An update on my Build so far. Completed the launch ian smith attached the following image(s): Current builds.Hachettes build the bismark,HMS Victory, HMS Hood. Finished Builds Corel HMS Victory cross section.
Hull up to issue 19. Next step Fairing the hull. ian smith attached the following image(s): Current builds.Hachettes build the bismark,HMS Victory, HMS Hood. Finished Builds Corel HMS Victory cross section.
Middle gun deck, planked with some of cuts of teak, 1 x 3mm planks. ian smith attached the following image(s): Current builds.Hachettes build the bismark,HMS Victory, HMS Hood. Finished Builds Corel HMS Victory cross section.
Very good solid build Ian  Regards Mike MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
Well done Ian, she's looking ship-shape!
You are on the right track there Ian. Sterling job so far Rgds, Hans "It's okay to make mistakes. mistakes are our teachers - they help us to to learn, even if it is painfully" Current Build: Endeavour Cross section,D51 Completed: HMS Victory Under the bench: Endeavour x 2,Sovereign of the Seas, Akagi and The Black Pearl!HMS Victory Cross Section
Thank you for the coments Mike, Stefan and Hans much appreciated Ian Current builds.Hachettes build the bismark,HMS Victory, HMS Hood. Finished Builds Corel HMS Victory cross section.
Hi Guys Just a quick update to my build, The planking has been done for the first six rows, The lower gun ports have been cut and the stern gallery planking has been shaped. up to issue 24 in the magazine. ian smith attached the following image(s): Current builds.Hachettes build the bismark,HMS Victory, HMS Hood. Finished Builds Corel HMS Victory cross section.
Hi Ian! It looks great mate! I would like to ask is it possible for you to take a picture of the stern from the side to check the side profile of the transom and false keel. Darron
