Varnishing Options
JAW
#1 Posted : 26 January 2012 20:49:16
Rank: Beginner Level 3
Hi All,
I am up to issue 83 and I was wondering, would you recommend varnishing the top decks at this point, it has not said so in the magazine (unless I have missed it) but I can see I might not get such a good finish once I have added the canons and stairs.
Thanks again
JAW
#2 Posted : 26 January 2012 20:58:37
that would make sense to me
benny
#3 Posted : 26 January 2012 21:52:51
me too, once you have got the decks as you want them get them sealed,add the details then give another coat and so on 3 or 4 coats of varnish wont hurt plus its a dust repellent if your wood is still slightly rough even with a stain the dust will get caught up
cheers benny
Ger C
#4 Posted : 27 January 2012 02:07:54
Hi,
new to this type of modeling but I presume that the wood needs to be varnished or oiled,
should this be done as the stages progress or left to the end,
thanks,
Ger
Hans
#5 Posted : 27 January 2012 10:55:32
Hi Ger C. As Benny and Jase have said do it as you are going along. The more coats the less dust can settle into cracks. Hope this helps
Rgds, Hans
Endeavour Cross section,D51
Completed: HMS Victory
JAW
#6 Posted : 27 January 2012 18:59:55
Thamks guys
I will varnish my upper decks tonight. After I have made the thirty four posts for the timber heads. Is it just me or is getting harder and harder to keep up.
JAW
benny
#7 Posted : 28 January 2012 13:59:14
JAW wrote:
Thamks guys
JAW
hi dont worry about keeping up take your time i am also way behind the build but its more important not to rush things
cheers benny
Ger C
#8 Posted : 30 January 2012 01:58:05
lovely build, keep up the work
This page was generated in 0.106 seconds.
