Joined: 25/01/2010 Posts: 459 Points: 1,367 Location: Bridlington
Hi Robert I am not building the Surprise, but I would be proud to have them aboard my builds any time  I think you have done a cracking job  keep up the good work  Regards Mike MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
Joined: 13/01/2012 Posts: 605 Points: 1,630 Location: Bucks
hi rob, i think they look terrific and i am definately going to do mine same as.Painting would have taken out some detail but this stuff is awesome. Is it permanent or does it rub off to highlite detail of any discription and what is it called. regards ,ian HMS Surprise HMS Snake HMS Bounty HMS Royal Caroline HMS Victory rebuild HMS Supply
Great build rob Love the danish oil you used on bottom of hull ian Current builds.Hachettes build the bismark,HMS Victory, HMS Hood. Finished Builds Corel HMS Victory cross section.
moriarty wrote:hi rob, i think they look terrific and i am definately going to do mine same as.Painting would have taken out some detail but this stuff is awesome. Is it permanent or does it rub off to highlite detail of any discription and what is it called. regards ,ian Hi thanks moriarty, after cleaning the brass cannon's (degreasing them etc) I dipped them in the Carr's solution for about 45 Seconds. I then neutralised them in Water (think you should use the proper neutralizing solution though} let them dry and, All the cannon's you see are what they look like after I rubbed the soft residue off with my fingers lol, Could of used a tissue. Regards
Rob
Bridlington.
Built Flying Scotsman (Train). Collecting HMS VICTORY
I think the cannons look great “Whenever you find yourself on the side of the majority, it is time to pause and reflect.” -Mark Twain
 The cannons look a treat m8 Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
 If Any body wants to you can look at all my pic's on Picasa if you click the link below. https://picasaweb.google...er=0&feat=directlinkRegards
Rob
Bridlington.
Hi Rob  i like the look of your canons  i used Krick blackener on mine but it took hours rather than seconds  so do u mind me asking what is this Carrs blackener and where can you get it i have seen Carrs products in Halfords but not blackener Cheers ps liked your photo album
budgie wrote:Hi Rob  i like the look of your canons  i used Krick blackener on mine but it took hours rather than seconds  so do u mind me asking what is this Carrs blackener and where can you get it i have seen Carrs products in Halfords but not blackener Cheers ps liked your photo album OOPS Only just seen your post, you can get CARR'S Metal blackening for Brass off the net, try the link below. http://www.google.com/ur...=m9u06NJyWdcluycF6kxHQA
Rob
Bridlington.
Off post but, I got the Carr's black for while I was (still am) building the Flying Scotsman.  https://picasaweb.google...er=0&feat=directlinkRegards
Rob
Bridlington.
Any body know what part contained the cannons Regards
Rob
Bridlington.
It's A shame we have to Finnish off the cannons ourselves, Bras Wire in and Soldered and all Blackened, will have to paint the pins as there Not Bras,  its not finished yet, going to finish this one then copy the rest off that one.   Regards
Rob
Bridlington.
Scotsman is looking good, is she static or cdoes it run? Which make of paint/shade of green did you opt for?
Tomick wrote:Scotsman is looking good, is she static or cdoes it run? Which make of paint/shade of green did you opt for? Hi Tomick n thanks, yes it will run but I have not put a motor in, but you can put one in anytime. The paint colour is, Apple Green, got it from the paint maker that supplied the newly built A1 Class Locomotive Tornado. WHATS GONE WRONG WITH SOME OF MY PIC'S Regards
Rob
Bridlington.
Looks like a photo upload problem? Lucky guy with the green find
Joined: 25/04/2010 Posts: 748 Points: 2,285 Location: bognor regis
hi did you put your pics on a site called mega upload because they said today on the radio that the site has been stopped and peoples pictures will be deleted just a thought cheers benny
Hi benny, no I use Picasa, I think Ive cured the prob, think it was a Picasa share prob, google keep making changes, then you've got to try to figure out what you've done wrong lol. Regards
Rob
Bridlington.
Different Stages. but still not complete   Regards
Rob
Bridlington.
hi rob is it worth changing to photobucket we dont seem to av probs on there cheers benny
Guest (8)
