Hi Guys I have collected 83 issues of build the victory so far. As i am still finshing a radio controll model of the Bismarck, which is nearly compleated. I thought i would make a start on the stern crest moulding of the victory inbetween doing some bits of my bismarck. attached are some images of the results. ian smith attached the following image(s): Current builds.Hachettes build the bismark,HMS Victory, HMS Hood. Finished Builds Corel HMS Victory cross section.
sorry guys my three year old nice has been pressing buttons on my p/c whilst i eas out of the room. can any one please tell me how to delete the repeated posts Ian. Current builds.Hachettes build the bismark,HMS Victory, HMS Hood. Finished Builds Corel HMS Victory cross section.
Joined: 25/03/2010 Posts: 472 Points: 1,357 Location: Hyde
Hi Ian, thanks for sharing. There is little problem with your second photo. It is completly out of focus. Could you retake it and repost it please? All details of your precision painting are gone becouse of this.
Thanks tom, did not put my camera on macro. hope second one is better ian. Current builds.Hachettes build the bismark,HMS Victory, HMS Hood. Finished Builds Corel HMS Victory cross section.
Hi guys I am doing my Victory in the painted version, with copper bottomed hull. i have started with the keel and ribs first as i have loads of issues. I will be doing the Cannon, Anchor and the launch as a evenning project later on. I have made the complete keel section and attached it to a build board. also have made the ribs upto issue 12. The ribs in attached photos are only dry fitted on the keel. ian smith attached the following image(s): Current builds.Hachettes build the bismark,HMS Victory, HMS Hood. Finished Builds Corel HMS Victory cross section.
Hi Ian, my that brings back memories,looking great Ian, I felt at this stage it helped to put Balsa Fillets In the Bow and Stern,and later on along the base of the Hull between the ribs, but then you know how I love Balsa MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
Thanks for the comments mike, any advise always welcome. Current builds.Hachettes build the bismark,HMS Victory, HMS Hood. Finished Builds Corel HMS Victory cross section.
How are the ribs have they rectified 12 and 15? MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
hi mike rib 15 is short of the bottom of the keel will probably have to build it up slightly when get to fairing of hull. ( any hints or tips welcome)ian Current builds.Hachettes build the bismark,HMS Victory, HMS Hood. Finished Builds Corel HMS Victory cross section.
Hi Ian, nice to see your build mate, it is looking good. As for rib 15, some of us found it necessary to build up the frame so that it was level with the keel...I used some spare 2mm x 3mm planking soaked in hot water for 20 mins or so then secured the wet planks onto the frame and allowed the planks to dry in place...then sanding it down even with the keel...
Enjoy your build mate...and keep the pictures coming... Current Builds: Deagostini HMS Victory: Deagostini HMS Sovereign of the seas. Completed Builds: Del Prado: HMAS Bounty: Hachette: RMS Titanic: Del Prado: Cutty Sark...
hi jonny Thank you for the comments and information about building up rib fifteen much appreciated Ian Current builds.Hachettes build the bismark,HMS Victory, HMS Hood. Finished Builds Corel HMS Victory cross section.
Hi guys attached photo of completed ribs up to issue 15. ian smith attached the following image(s): Current builds.Hachettes build the bismark,HMS Victory, HMS Hood. Finished Builds Corel HMS Victory cross section.
Good stuff Ian MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
Joined: 26/09/2010 Posts: 851 Points: 2,565 Location: Walsall
Nice strt there Ian. Keep up the good work.
Foz
Thanks for the kind comments mike and foz. Current builds.Hachettes build the bismark,HMS Victory, HMS Hood. Finished Builds Corel HMS Victory cross section.
Hi guys just a quick update on my build so far. i am still filleting between the ribs on my hull, i Will post some pictures later. below a picture of issue 1 cannon. Please feel free to leave comments, Ian ian smith attached the following image(s): Current builds.Hachettes build the bismark,HMS Victory, HMS Hood. Finished Builds Corel HMS Victory cross section.
Good work Ian  Is everything going according to plan?Regards Mike MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
Looking good clean and tidy and as Mike says, brings back memories. Keep it up. Rgds, Hans "It's okay to make mistakes. mistakes are our teachers - they help us to to learn, even if it is painfully" Current Build: Endeavour Cross section,D51 Completed: HMS Victory Under the bench: Endeavour x 2,Sovereign of the Seas, Akagi and The Black Pearl!HMS Victory Cross Section
Joined: 07/01/2011 Posts: 399 Points: 1,212 Location: Penhill Estate, Western Cape, ZA
Looking good Ian. Is the cross-member of your Anchor the right way up? I thought the straight edge needs to be at the top?
thanks for noticing that stefan. it should be other way up. good job i did not have to glue it. i should be able to remove the stock and turn it over. Ian Current builds.Hachettes build the bismark,HMS Victory, HMS Hood. Finished Builds Corel HMS Victory cross section.
