56 Pages «<1920212223>»
#401 Posted : 04 January 2012 18:18:19
No SeanCursing I think you are more right than me.
By the way you asked for photos of the Airfix Zero I posted someBigGrin Cheers Mike
S2ksean
#402 Posted : 04 January 2012 18:22:10
Lol cheers il have a look
CURRENT BUILDS
Mclaren MP4-23
HMS Pandora
#403 Posted : 07 January 2012 19:08:26
ISSUE 18
Hi Team here is how she looks now!:-
BigGrin
#404 Posted : 07 January 2012 20:02:28
Taking shape. starting to look like a ship.
#405 Posted : 08 January 2012 11:26:36
IT certainly is JaseBigGrin
#406 Posted : 11 January 2012 11:33:17
ISSUE 19 DECK SUB-ASSEMBLIES
Hi Team here we are again week 19. continuing with sub- assemblies on the deck.
For this I just removed the deck section, rather than work on the whole ship.
This is what we received:-
#407 Posted : 11 January 2012 11:36:22
I numbered the parts, and cut them out, cutting from both sides of the fret:-
#408 Posted : 11 January 2012 11:47:41
The parts as you can see are very "fiddly" it is worth taking the time to trim and sand them a little more than usual.
I then assembled the parts as per the instructions ( At no point should the parts at this point be glued to the deck no 73)
Here are the photos:-
#409 Posted : 11 January 2012 11:58:11
At this stage I left the glue to dry.Then I must sand the corners of the sub-assembly, and finaly fit it to deck 73 using parts 101 and 102.
Questions and comments welcomeBigGrin Thanks for watching. Mike.
#410 Posted : 12 January 2012 22:55:38
After the build this time she looks like this:-
#411 Posted : 12 January 2012 23:00:23
The part we have built is then fitted and glued in place on Deck 73, at the same time fitting pieces 101 and 102 to anchor to other parts already fitted
That all this time, thanks for watchingBigGrin Mike
#412 Posted : 12 January 2012 23:04:51
I have a question if I may. There are a number of ladders and doors on the superstructure you are just building. do you know if you get them or not? some are hard to see so they may be left off.
build looks great by the way BigGrin
#413 Posted : 12 January 2012 23:11:43
Jase questions are really appreciatedBigGrin
There are brass etchings coming (I understand )that in some way cover the sub assemblies, but it is something I have not seen, its only been referred to in the magazine.
Thanks for askinMikegBigGrin
#414 Posted : 13 January 2012 14:43:25
Hi Mike, Jase
To answers jases question the bismarck i made had all the ladders between the decks and even ladders up the sides of bulkheads.
i would think the hood would go into the same amount of detail on superstructor. Ian. BigGrin
#415 Posted : 13 January 2012 18:13:06
Great new Ian,BigGrin we have lots to look forward to!
Cheers Mike
#416 Posted : 18 January 2012 13:09:35
ISSUE 20 BOW DECK PIECES
Hi team the parts we have received this week on the fret are different to the ones depicted in the instuctions.
Two parts (103) are missing from the fret but the way the other parts are configured it looks like they are not needed any way, but to be on the safe side I have made copies of these two parts, and fitted them.
I will post the modifications I have done with photos later in the day.
MikeBigGrin
#417 Posted : 18 January 2012 14:35:27
hi Mike
Noticed that myself yesterday, I did ask the question wether anyone else had the problem. But my build log isn't showing. Glad it wasn't just my parts that were missing.
chris
#418 Posted : 18 January 2012 16:25:26
ISSUE 20 BOW DECKS
Hi team I have spoken to Hachette who say the parts are indeed missing, and are to be included in a future issue.
If in the meantime builders wish to progress, the missing parts can be easily replicated.
I will show my mods this evening with photosBigGrin
Mike
#419 Posted : 18 January 2012 21:58:06
HMS HOOD ISSUE 20 BOW DECKS
Hi Team this is my build diary as promised
The two items that should have been on the fret I replicated:-
#420 Posted : 18 January 2012 22:13:32
ISSUE 20
Hi again Team,
You will see I have replicated parts 103.
You will also notice part 104 has a Half rib extrusion where it fits over rib 37 (the instructions show no extrusion on the part 104 at this point)
Part 104 has a full rib extrusion where it fits over rib 39 (the instructions show half a rib extrusion at this point)
Part 105 has no rib extrusion where it fits over rib 39 (the instructions show half a rib extrusion at this point.)
I made a part I have called 104a to glue to part 104 in order for it to support the edge of 105 see the photos:-
This page was generated in 0.396 seconds.
