Deadeye's (Just out of interest) Options
jeff averre
#1 Posted : 10 January 2012 16:53:33
Although I did not not get one, I remember some of you bought a small contraption for rigging the 'deadeyes', I think it was to ensure the distance between them was uniform and also making the job easier. however, since the 'deadeyes' are fitted to the chainwales, is it still possible to use the machine? It may be possible if they are not fitted to the ship!
I'm nowhere near that stage for fitting the shrouds, but it looks to be a 'fiddly' job doing 'in situ' on the ship. I thought we may have been able to rig the 'deadeyes' and 'shrouds' to the 'chainwales' and finish them off by fitting to the ship then tying the shrouds off at the mast.
The way it's done in the oficial build diary looks a bit 'out of control' but if that's the way it has to be!
Any thoughts on this would be most welcomeConfused
P.s. I did not glue the masts together earlier on so as to give me room to fasten the shrouds.
heers, Jeff
daffy09
#2 Posted : 10 January 2012 17:41:03
I'm one of the people who bought one of those 'reeving and spacing' tools, but I think it may well be redundant now after seeing how simple it is to obtain the correct spacing by using an offcut of wire bent to make a template to obtain the right distance between each of the deadeyes.
However, it has been very useful as the other end of the tool has a clamping device to hold the deadeyes when they're being tied. This has been invaluable to me as I kept dropping the deadeyes when trying to tie them by hand.
Happy building
David
This page was generated in 0.103 seconds.
