 Rank: Semi-Pro Level 2   Groups: Registered
Joined: 10/01/2011 Posts: 91 Points: 273 Location: South Africa
Awesome wok Stefan You should be proud
Gerrit
 Rank: Pro  Groups: Registered
Joined: 07/01/2011 Posts: 399 Points: 1,212 Location: Penhill Estate, Western Cape, ZA
Thanks gentlemen. I hope it's ok to post pictures as I go instead of the finished product - of which there are much more worthy examples than mine. 3 strips of the lower wale pinned:  Bottom strip of the lower wale fitted. This was easier than I anticipated   Lower wale complete, upper wale pinned:
Joined: 20/03/2010 Posts: 462 Points: 1,299 Location: Tortuga !
Lookin Good Stefan, Keep it up Happy Building, Russ On the workbench: My Victory Build Diary - Victory Cross Section Build Diary - Black Pearl Build DiaryUnder the Bench: Millenium Falcon, Black Pearl x 2, Coral Victory Cross Section, De Lorean
Mooi so Stephan. Beauty in the making. Looking real good nice, clean and tidy. Keep it up Rgds, Hans "It's okay to make mistakes. mistakes are our teachers - they help us to to learn, even if it is painfully" Current Build: Endeavour Cross section,D51 Completed: HMS Victory Under the bench: Endeavour x 2,Sovereign of the Seas, Akagi and The Black Pearl!HMS Victory Cross Section
Nice stern planking neater than mine “Whenever you find yourself on the side of the majority, it is time to pause and reflect.” -Mark Twain
Joined: 15/09/2010 Posts: 175 Points: 517 Location: Durban RSA
A lovely build,well done keep, us up to date.
Happy building
Athol
Thanks all - I really appreciate your comments. All 4 wales fitted, gun-port openings cut and the holes drilled for the gun-port lids: (I wish I took the time and made a jig to get the holes perfectly square to the gun ports - one or 2 that came out a little skew)  Little jig to assist with supporting the wriggles while marking & cutting:  Cutout of the wriggles complete:
Very nice work in deed Stefan...great job mate...keep the pictures coming... Current Builds: Deagostini HMS Victory: Deagostini HMS Sovereign of the seas. Completed Builds: Del Prado: HMAS Bounty: Hachette: RMS Titanic: Del Prado: Cutty Sark...
Very proffesional!
Looking very good.
Steve..
Thanks Johnny & Steve! The dolphins fitted and the Hawseholes drilled:  The stem trim:  3rd hole drilled in the stem:
Fantastic Build Stefan Mike MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
Looks loverly. “Whenever you find yourself on the side of the majority, it is time to pause and reflect.” -Mark Twain
Thanks Mike & Jason! I've started with planking the middle deck, but had to remove all the planks due to a measurement/marking error of the centre-line. Below is a picture of a little jig I built to mark 13mm from the centre-line. I'm temporarily deviating from the official build in order to make the grates narrower as per Son of Bulwark.  Here is the first try:  And removed again
Finally fished the deck planking over the weekend:  The fingers fitted  Decking right to the edge on the hull on the Portside bow  Space left at the back - as per the instructions
Good Stuff as usual Stefan  Regards Mike MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
Thanks Mike! Some areas to be improved upon, but a very good preparation for planking the upper deck(s) that follows
Nicely done Stephan, as usual a beautifull clean and tidy job. Well done. Rgds, Hans "It's okay to make mistakes. mistakes are our teachers - they help us to to learn, even if it is painfully" Current Build: Endeavour Cross section,D51 Completed: HMS Victory Under the bench: Endeavour x 2,Sovereign of the Seas, Akagi and The Black Pearl!HMS Victory Cross Section
Great Stuff Stefan...She is coming along brilliantly!! Current Builds: Deagostini HMS Victory: Deagostini HMS Sovereign of the seas. Completed Builds: Del Prado: HMAS Bounty: Hachette: RMS Titanic: Del Prado: Cutty Sark...
great build stefan. thanks for the heads up on anchor. Ian Current builds.Hachettes build the bismark,HMS Victory, HMS Hood. Finished Builds Corel HMS Victory cross section.
Hi Stefan, Your build look as good as ever,great lines,great build looking forward to more pictures,well done. Regards tf64. Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
Guest (6)
