Issue 96 lashings Options
Deepseacodmaster
#1 Posted : 09 January 2012 11:50:49
The last two photos of MR T's official build shows lashings to secure the top dead eyes instead of knots.
I am up to issue 68 and have just started to use .25 mm natural thread lashings to secure all my blocks.
Apart from looking better, I am finding it easier to get the correct lengths to the blocks each time.
I use a fishing fly tying method to make tubes on drill shanks using 2 x the diameter of the securing thread by glueing them with thinned down super glue and then cutting the tubes to length with a new razor blade.
I then glue them with thinned PVA glue onto the securing threads.
Is anybody else doing this and/or what method are you using.
I think I will be replacing most of the knotted blocks I have alredy tied especially on the hand rail ropes.
The photos show a black lashing on one block for illustration purposes.
First Build HMS Victory and HMS Endeavour
Also Krick steam boat "Victoria"
Cheers
Ivan (Ordinary Seaman)
http://www.old-glossop.com
#2 Posted : 09 January 2012 14:33:06
Hi Ivan,
This is the way I use on some of my builds. It is so much quicker to do and looks neater too.
Chris..
BigGrin BigGrin
riff-raff
#3 Posted : 09 January 2012 15:26:40
A great idea and I will certainly have a go at thatBigGrin
Built:
#4 Posted : 09 January 2012 15:52:58
My build simply reflects that of the magazine., presumably you mean issue 92 rather than issue 96, because 96 is way off being posted up Huh
Deepseacodmaster
#5 Posted : 09 January 2012 17:09:48
You are correct Mr T
Cheers
#6 Posted : 09 January 2012 18:34:45
hi deepsea,yes this is a way of doingit,if you go to index,and look for 'karls tips and tricks,you will see I covered this subject on how to'.
choosing the right colour thread helps to keep thing looking right,when I get to that stage,all the shrouds and ratlines and also dead eyes will be black,so the whippings will be black also.the landyards(between both deadeyes) will be natural colour.
This page was generated in 0.107 seconds.
