 Rank: Pro Groups: Registered
Joined: 15/09/2010 Posts: 175 Points: 517 Location: Durban RSA
I am looking at starting to build a cabinet for the Victory. Before I purchase the cabinet material can anyone confirm that my assumptions below are correct. The overhaul dimensions give in the pamphlet is Length 1250mm, Height 850mm, Beam 450mm. Am I correct in assuming that I need to increase these dimensions by approx 100mm to allow clearance for the cabinet. Happy building Athol
Joined: 15/04/2010 Posts: 1,266 Points: 3,841 Location: The Quantock Hills,Somerset
Dont forget to allow extra height for a display stand  ....could be embarrassing otherwise Rob Nolli Illigitimi Carborundum!!!Current Builds: HMS Victory, SV Thermopylae
Atholm wrote:I am looking at starting to build a cabinet for the Victory. Before I purchase the cabinet material can anyone confirm that my assumptions below are correct. The overhaul dimensions give in the pamphlet is Length 1250mm, Height 850mm, Beam 450mm. Am I correct in assuming that I need to increase these dimensions by approx 100mm to allow clearance for the cabinet. Happy building Athol Any chance you could do a build diary for this i need to build a display case but not really sure how to go about it “Whenever you find yourself on the side of the majority, it is time to pause and reflect.” -Mark Twain
Joined: 07/01/2011 Posts: 399 Points: 1,212 Location: Penhill Estate, Western Cape, ZA
I'm going to wait to do mine until I've fitted all the masts. Also not sure what lighting to use
jase wrote:Atholm wrote:I am looking at starting to build a cabinet for the Victory. Before I purchase the cabinet material can anyone confirm that my assumptions below are correct. The overhaul dimensions give in the pamphlet is Length 1250mm, Height 850mm, Beam 450mm. Am I correct in assuming that I need to increase these dimensions by approx 100mm to allow clearance for the cabinet. Happy building Athol Any chance you could do a build diary for this i need to build a display case but not really sure how to go about it Same here, a build diary would prove very useful if one was available, just to give me some ideas happy building David
Rob thanks for the reminder about the stand.
I think it will be a few weeks before I start I am looking at different options, as my woodworking tools are all hand held (some powered) therefore need to take that into consideration in the final design.
My intention is to use acrylic sheets (perspex) due to the weight and strenght.
If anyone is intrested I Googled "How to make a cabinet for a model ship" and had some intresting links with some good ideas.
I will provide some more details when the design finalised.
Happy builing
Athol
