Display cabinet size Options
Atholm
#1 Posted : 09 January 2012 08:58:25
I am looking at starting to build a cabinet for the Victory. Before I purchase the cabinet material can anyone confirm that my assumptions below are correct.Confused
The overhaul dimensions give in the pamphlet is Length 1250mm, Height 850mm, Beam 450mm. Am I correct in assuming that I need to increase these dimensions by approx 100mm to allow clearance for the cabinet. BigGrin
Happy building
Athol
Dontshootme
#2 Posted : 09 January 2012 09:01:27
Dont forget to allow extra height for a display standBlink ....could be embarrassing otherwiseBlushing
#3 Posted : 09 January 2012 11:57:04
Happy building
Athol
Any chance you could do a build diary for this i need to build a display case but not really sure how to go about it Blink
StefanDV
#4 Posted : 09 January 2012 13:02:40
I'm going to wait to do mine until I've fitted all the masts. Also not sure what lighting to use
daffy09
#5 Posted : 09 January 2012 13:04:07
Happy building
Athol
Same here, a build diary would prove very useful if one was available, just to give me some ideas
happy building
David
Atholm
#6 Posted : 10 January 2012 14:12:03
Rob thanks for the reminder about the stand.
I think it will be a few weeks before I start I am looking at different options, as my woodworking tools are all hand held (some powered) therefore need to take that into consideration in the final design.
My intention is to use acrylic sheets (perspex) due to the weight and strenght.
If anyone is intrested I Googled "How to make a cabinet for a model ship" and had some intresting links with some good ideas.
I will provide some more details when the design finalised.
Happy builing
Athol
This page was generated in 0.189 seconds.
