12 Pages <1234>»
tf64build Options
#21 Posted : 05 January 2012 21:40:47
Thank you MGW and Jase for your intrest in my Victory.
tf64.
saintsman123
#22 Posted : 05 January 2012 21:47:10
great work trev, if anything i think the work done lining the inside if the cabin/gallery windows is more impressive, thats not to take anything away from all the other great model work. well doneThumpUp ThumpUp ThumpUp
Come on you Jimmies
#23 Posted : 05 January 2012 22:01:29
I think you have done a great job and would look nice lit up
#24 Posted : 05 January 2012 22:41:08
Awesome TrevBigGrin
Son of Bulwark
#25 Posted : 05 January 2012 23:09:03
What can I say! Drool Drool Drool
I love the detail mate! Love I totaly agree with Mike 'Awesome Trev'
Drool Drool Drool
Hans
#26 Posted : 06 January 2012 20:28:10
Well done Trevor it looks amazing to say the least. You obviously have the patience of a saint. Will wait patiently for your update.
Rgds, Hans
Endeavour Cross section,D51
Completed: HMS Victory
#27 Posted : 07 January 2012 11:06:05
Dedication to the extream love it
#28 Posted : 08 January 2012 00:04:39
Thank you for viewing my post Saintsman/Jase/MWG/SOB/Hans/Arpurchase,it makes it all worth while,more pictures to follow.
tf64.
#29 Posted : 25 January 2012 23:04:33
Hi All,
A few more pictures on the Wardroom,you know that I have built a table, well now I have put food on it,what I have done is to hand model and hand paint bread, bananas,look for brown one,and tomato's from clay and bake in the oven with the sunday roast.The bowls were also made from clay
I rolled to a very small ball and pushed a small stick into the middle then baked.The Officers were made the same way but I had to model by hand.
The Hammock's were made from cloth and painted white which gave me the affect I was looking for,and then hung from the rails.The wash bowls with the red rims, again clay bake and hand painted, both stamped in the center with a V. I do realize that this is not to scale.
So please have a look at the pictures and thanks for your intrest.
Regards tf64.
#30 Posted : 25 January 2012 23:08:43
that's just amazing I am speechless!!!
#31 Posted : 25 January 2012 23:10:54
Fabulous TrevBigGrin very ingeniousCool Regards MikeLove
Hans
#32 Posted : 26 January 2012 09:15:40
Talk about extreme. Well done Trev you have some fantastic ideas there. I do think your build is going to look exceptional.
Rgds, Hans
#33 Posted : 27 February 2012 23:34:20
Hi Shipmates,
Just finished the last piece of furniture to add to the Wardroom which is now completed.
This is the Wardroom which will be lit up.
This picture shows the planking of the lower deck which I know will be covered over but it is good practice for the top deck.
this picture shows trenails added to the deck.
Thank's for looking.
Regards tf64. (trev)
farrabass
#34 Posted : 28 February 2012 00:25:25
Message was deleted by User.
#35 Posted : 28 February 2012 00:30:22
Terrific work TrevBigGrin Love itBigGrin Steve,BigGrin if you click on a photo you get a full size versionBigGrin Regards MikeBigGrin
farrabass
#36 Posted : 28 February 2012 00:40:10
Hans
#37 Posted : 28 February 2012 07:05:46
Absolutely marvelous work Trev. Fantastic detail. Wish I had done this earlier, as my decks up to the quarter deck are already in place, so am doing it the hard way by removing back of the the gallery. Will post my pics the weekend. Beautiful work, my friend, beautiful work. Brilliant craftmanship. Dont forget to plan your lighting and fit, as you are building otherwise it becomes a real pain in the butt.
Rgds, Hans
#38 Posted : 28 February 2012 23:26:03
Hello MWG,
Thanks for viewing my post,it has taken some time to build the Wardroom,it feels like I have built it twice with all the corrections I have made, but as you know yourself that's the fun of it.
Regards trev.
Hans hello,
Thank you for your kind words,regarding the lighting of the wardroom as you say think ahead, your so right,so I have planed to use LED ( light emitting diode)I think it is a absolute treat for any modeller,I have made up a mock up on a small mother board with a resistor,but it is still under test (regarding heat)I think if I reduce down to 6v it will run cold that is what I am testing now.
Regards tf64 (trev)
Hans
#39 Posted : 01 March 2012 13:02:30
Hi Trev. I will be posting my pics soon, just need plenty of tidying up to do at the moment. I discovered a 12 volt led strip that come in 5 metres flexible self adhesive roll and you are then able to cut every 3 led's. It has a positive and negative patch on either end, where you can solder the wires in series for corners, bends, extentions etc. I have used a fine comms cable, the one used for security gates and intercoms, that I strip for the lenghts I need. A laptop 12 volt battery charger reduces our 220v to 12vdc. Looks fantastic when lit. If it helps I can post the specs. I have not found that the LED's produce too much heat, it only provides 4.8 to 5w alum. The strips themselves appear to be a foil of sorts that defuses the heat as well. Trust this helps your cause.
Rgds, Hans
#40 Posted : 07 May 2012 20:01:30
Hello Shipmates,
Well I found time to work on the planking on the Middle Deck most of the deck is layed with individual planks with trenails(cocktail sticks).Then on to make the grids.
Thanks for your time.
Regards tf64.
12 Pages <1234>»
This page was generated in 0.253 seconds.
